Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Racing fuel
Old Apr 14, 2001 | 02:33 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Racing fuel
Although I haven't had to buy any VP fuel yet I'd like to show a comparable cost. All prices in Canadian currency and in liters.
20 liters of 112 octane C-12 VP fuel = about $50 canadian (I don't have exact numbers but it's somewhere around there)
Homebrew racing fuel using 92 octane and xylene (I can't find any Toulene yet). This mixture is supposed to raise 92 octane gas to 99.5
14 liters of 92 octane at current price = $9.65
6 liters of xylene solvent = $35.31 (inc tax)
Total cost for 20 liters of homebrew $44.96
A savings of about $5 and not as good a mixture as real racing fuel that is 12 full points higher.
Unless I could get xylene dirt cheap it would still be better to buy VP fuel.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Apr 16, 2001 | 12:06 AM
Basett Racing's Avatar
Depending on your compression ratio, 112 may actually be too much octane to burn effeciently. On a 11:1 CR 350 that was in my 82 Z28 would actually slow down almost a tenth or so with 110 octane compared to 105. I bought several gallons of Sunoco 114 from a late model dirt track racer at the end of they're season and it slowed it down even more than the 110 did. The next trip to the track, we mixed 2 gallons of the Sunoco 114 and 2 gallons of 92 octane pump gas and the car went its best ET ever by .006, so be sure you have enough compression to fully benefit from the 112, and If not just blend a little pump gas until you find what runs fastest.
82 Z28 350, Ported #882 Heads, Performer RPM cam and intake, hedman headers,650 Demon carb,
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET: 12.52@107.2
Future plans: Dart headed, Roller cammed 383 in early '01
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
New Best ET: 14.91 @92.9
Bassett Racing
Mid Atlantic F Body -82 Z28 Page
R.I.P. Dale Earnhardt #3
Old Apr 20, 2001 | 06:23 PM
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
xylene?? I use that stuff at work, what's the ratio? I never heard of that. I'll have to check out what we pay for it.
Hey Stephen, I tried to email you but your email wasn't working. Your car looks great, good luck with the 460 this season. How did you fill in your headlights?? I like it!!
92 RS, 350, Street & Performance MPFI, TFS heads,
Crane Rollers,
MSD Digital 6 Plus, 22lb injectors,
ZZ3 cam, Edelbrock Headers 1 5/8, 3" Exhaust,
Hi Flow 3" Cat, stock T-5,
stock rear 3.08, koni yellow adjustable front, twin turbo glass hood, T-tops, Auto Meter Ultra Lite Series 2 5/8 gauges, Teal Green
Old Apr 20, 2001 | 08:12 PM
AlkyIROC's Avatar
Car: 87 IROC L98
http://www.gnttype.org/techarea/misc/octanebooster.html
oops I missed the part about the headlights. Kemlite fiberglass, durabond (I think that's what it was) and bondo. It's not going to win any car shows for the quality of the work but it looks better than open headlight holes.
** non tech part now but needed to explain e-mail **
I watch my mail server logs. It's possible you either sent it from an IP range that I block or hat a return address that I block. Whith so much spam out there I have some basic block on my mail server and I only get about 1-2 spams a month.
I just looked through the last 4 days logs. A couple of attempts could have been you. @yahoo.com and @hotmail.com return addresses are automatically blocked. All asia/pacific ip's are blocked (unfortunatly AU and NZ get blocked also) and just recently I blocked everything from mindspring.
Sorry for any inconvinience but I'd rather miss a few ligitimate e-mails than get spam.
[This message has been edited by Stephen 87 IROC (edited April 20, 2001).]
Old Apr 23, 2001 | 07:25 AM
TTA's Avatar
TTA
Just for a comparison.
VP 108 Costs me 4.50 at the track
CAM2 110 Costs me 3.69 at the Gas Station
VPC16 116 Costs $7.00 at the track.
I usually run Cam2 cause its cheaper and I havent had any problems with it. If I am trying something new or rasing the boost a little I will run C16 for Saftey. If its ok, I'll try the 110.
Mike
1989 Turbo Trans-Am
11.25@121.25
Daily Driver
1998 Trans-Am LS1 6 Speed
13.10@106
Slow POS sitting in the Driveway awaiting repairs and then its For Sale. No More V8 Cars for me.
92camaroJoe
Jul 29, 2023 07:57 PM
italiano67
Dec 11, 2016 09:21 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
