Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
how to hook up with BF drag radials??
Old Apr 29, 2001 | 07:12 PM
e-man's Avatar
Car: 89 formula
Engine: 383
How are you guys doing it? I tried 20psi to 25psi 25psi worked best,I tried 3sec. and smokey burnouts,I tried stalling the converter at 1000rpm no luck couldnt get better than a 2.00 60ft that isnt any better than the 2.01's I was getting with the radial TA's!
89 350 TPI,comp cam,edelbrock intake base,SLP headers,highflo cats,flomaster cat back,accel 300+ ign,ported plenum and runners,ported maf,auto w/shiftkit,cold air induction,AFPR,Ed wright chip,3.23 posie best ET 14.011@98.72mph without cam/New best 13.926@98.27mph
Old May 1, 2001 | 05:41 AM
e-man's Avatar
Car: 89 formula
Engine: 383
I know some of you guys are useing them help me out.
Old May 1, 2001 | 06:35 AM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
My BFG's slowed me down. At lest you got a .06 improvment. I was told that the BFG's where boging the car try a little more air pressure is what I was told.
Old May 1, 2001 | 08:58 AM
spud's Avatar
Car: 82 & 91 Firebird
Engine: 400 & 355
Transmission: TH350 & 700
Axle/Gears: 4:11 & 2.72
Are you spinning, or not. If its spinning try dropping the air pressure, I run mine at 14 psi. They look like slicks they wrinkle so much, but they don't cup like regular radial tires do. When a motor bogs it seems like it takes a long lime for the rpms to come up, Also the motor will sound like it has a massive load against it. If this is your problem then raising the tire pressure is what you need.
Later
John
82 Firebird,408,Dart Iron Eagle 215's,Cam 229/239, .498/.520,TH350 Tranny, 750 Speed Demon carb, Hooker Headers(I.E. POS) Manual steering, Also a cowl for the big hole in the hood.
Shooting for low 12's.
Check out my birds new home.
Old May 2, 2001 | 05:41 PM
Mark 89Formula's Avatar
2.01 on street radials is very respectable. You need a good converter to drop your 60' times to say the 1.7-1.8 range. It's tough to get much below 2.0 60' times with a relatively stock engine (ie. similar amount of low end torque) and stock converter. I'd view you DRs as an investment that will pay off in the future after a converter and/or gear change.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
Gordonr1973
Sep 29, 2015 11:59 AM
JSDaddy189
Sep 26, 2015 03:50 PM
