gonna try again!!!
gonna try again!!!
Well,Gonna go to the track tomorrow and see if i can not spin the whole way down the track.Right now I have 87 iroc "16" wheels,which I spun down the track with.Would you recomend letting out some air pressure or just running some 15x9 centerlines that i have.I got this big problem with hooking up at the track.Any help would be great.Btw...what PSI would yu reccomend?
http://community.webshots.com/user/blucamaro
I would get some M/T et streets or BFG drag radials, run them at 20 psi and go lower if its not hookin. On regular radials try about 25 psi, no lower.
91 B4C 305 TPI - SOON TO BE 383
TREMEC 5-SP, STOCK 1-BOLT REAREAND w/342 GEARS
K&N, AIRFOIL
EDELBROCK HEADERS, DUAL CAT TO HOMEMADE Y-PIPE & 3.5" SINGLE PIPE W/ FLOWMASTER
CRANK PULLEY, MSD, FUEL PRESS REG
COWL HOOD, WELD WHEELS
14.1@ 98MPH
OTHER RIDE
67 CAMARO - STREET CAR
BIG BLOCK, PUMP GAS
350TH w/ATI 10"
12-BOLT w/373 GEARS
10.90s ON MOTOR - ET-STREETs w/MUFFLERS
K&N, AIRFOIL
14.1@ 98MPH
OTHER RIDE
BIG BLOCK, PUMP GAS
350TH w/ATI 10"
12-BOLT w/373 GEARS
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You only let air out for slicks. Street radial tires will give you less traction with lower air because the sidewalls are so stiff they won't fold over. Instead the center of the tire will raise up only giving traction on the outer edges of the tire. Street radial tires work best at 32-35 psi. They also won't heat up in the water box the way a slick will so drive around the water box (to the inside away from the debris that they sweep out of it) and do a short dry hop to clean off the tires.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.69
Best MPH on a time slip: 121.52 altitude corrected to 127.76
Altitude corrected rear wheel HP based on power to weight ratio: 504.5
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
ok,kool....Well I'll figure out something by tomorrow,and I just got a digital camera so I'll get some pic's.hopefully not of me doing a massive burnout down the track........and Thanks again
