Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
hoping 13's?
Old Sep 2, 2001 | 03:30 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
hoping 13's?
i am trying to build a mid to high 13 second camaro. right now i am in the process of putting a 330 horsepower, 380 ft lb of torque 350HO crate engine in my car. next goes in a built th350 from tci. finally, i plan on some 3.42 gears and a posi. do you think 13's are a reality for me? what do you think i will run with nice launches on 275's with good traction? thanks.
Old Sep 2, 2001 | 03:48 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
I'd say yes.
89 RS
STILL Looking For:
An 87 IROC-Z28 350 TPI
Old Sep 3, 2001 | 10:50 PM
JJ's Avatar
JJ
I put that engine in a 5 speed IROC with 3.45 rear. I put the XE268 cam, 1.6rr's, and had some head work done to the vortec's. I didn't manage to get to a track before selling it, but did pull a LS1 from a roll. So, I think that engine could put you in the 13's - depending on launch and suspension of course.
Old Sep 3, 2001 | 11:26 PM
Basett_Racing's Avatar
However good it runs at the track, keep in mind that it will never run its potential on street tires. IMO going to a drag strip with a car with decent power on street tires is setting yourself up for disappointment. There's a lot of 13 second cars running 14's (sometimes even 15's) on street tires.
82 Z28 383, Ported 215cc Dart Iron Eagle Heads 72 cc Comb. Chambers, Comp custom grind Hyd roller cam, Speed Pro .250" domes, Wheeler Motorsports 4340 I beam rods, Eagle 5140 steel crank, Weiand Team G intake, Holley 830 DP, hedman headers
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET:11.60 @ 114.56, w/ a 7.34 1/8 @ 93.50, and a 1.622 60'
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
Bassett Racing
Old Sep 4, 2001 | 06:44 AM
86ZZ4's Avatar
Very ,very true Basset!!!!!!ck sig LOL
86 z28 zz4 ssm lift bars ,3.73 simesed runners and a traction deficient 13.707@101.02,on a 2.16 60 ft on 295/50/15 junk street rubber ,best MPH run 13.82@102.7,69 AMX,390 4 speed sticky tires and other stuff..12.94@102.3
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
LC2 TECH
Oct 13, 2015 11:53 PM
Fanatic1074
Oct 2, 2015 03:47 PM
sjorgens
Oct 1, 2015 07:54 PM
3.8TransAM
Oct 1, 2015 07:47 PM
