Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
hows 15.3 sound for an almost stock 92 RS ?
Old Aug 31, 2001 | 10:03 PM
DrStampede's Avatar
So does a 15.306 @ 88.71mph with a 2.145 60' sound good for a almost stock 92 RS with 305 and 5 speed??? I basically want to see how close I am to other 92 RS's that run and want to see if all the time i've put in the car are actually worth it.
Mods so far include K&N air filter, gutted cat with flowmaster, Moop sprints, KYB GR2 shocks, and a rear axle 3:27 Posi from an 89 Z28
oh ya and its also got 160 degre thermo and hypertech chip neithor of these mods did anything for my times.
[This message has been edited by DrStampede (edited September 01, 2001).]
Old Sep 1, 2001 | 03:55 PM
Basett_Racing's Avatar
15.30's with so few mods is very repectable with an L03. A set of headers and maybe a better chip should put you in high 14's. Other the mods you have, I have a set of Hedman headers, A Hypertech chip, and a set of 1.6 roller tips, and the best I've went was 14.91, but that was in cold Jan weather and the best the car has run this summer is a 15.18 @ 90.06
82 Z28 383, Ported 215cc Dart Iron Eagle Heads 72 cc Comb. Chambers, Comp custom grind Hyd roller cam, Speed Pro .250" domes, Wheeler Motorsports 4340 I beam rods, Eagle 5140 steel crank, Weiand Team G intake, Holley 830 DP, hedman headers
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET:11.60 @ 114.56, w/ a 7.34 1/8 @ 93.50, and a 1.622 60'
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
Bassett Racing
[This message has been edited by Basett_Racing (edited September 01, 2001).]
Old Sep 1, 2001 | 06:39 PM
mss's Avatar
mss
then where should i be ? i have an lg4 performer intake manifold , peformer 600 cfm carb , other than that basic tweaks , such as . open element air cleaner , absolutly no smog equipment , flowmaster 80 series muffler , and no cat , i cant take it to the track because the closest track is an hour away and im always too busy to go but a guesstimate would be ok . oh btw this is in an 87 z28 with 2.73 rear
Old Sep 2, 2001 | 10:50 AM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
mss I'd say mid 16's if you're stick and 17 automatic... I have basically the same setup except for 3.27 gears and 5 speed '84 engine which has a little less Hp... so that probably makes up for the gearing... I don't know what muffler I have... that shouldn't matter much.
1984 Firebird - Daily driver, 305 LG4, T5 - Hurst short shifter, Edelbrock 600 CFM Performer Carb - Edelbrock Pro-Flow air filter, gutted cat, IROC 16x8 Wheels, Goodyear P215/60/R16, AIWA bargain basement (from Sears of course) CD player, Fuzzy dice, Eight-ball shift ****
Check out my ride here $1600!! Bye Bye on board computer!
First Kill: 2002 Subaru Impreza WRX Wagon (1 person vs me with 2 passengers)
Old Sep 2, 2001 | 05:15 PM
NJ SPEEDER's Avatar
those are very good times for a LO3. the posi and the gears are prolly the biggest help. it sounds like you must have hooked pretty good too, what were your short times?
good job.
lata
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Sep 2, 2001 | 11:11 PM
DrStampede's Avatar
BEalive it or not I used to get better 60' times with the old axle 3:08 open. I've gotten 1.9 with the old one now my best so far is a 2.1
Old Sep 3, 2001 | 02:51 PM
NJ SPEEDER's Avatar
the gears may be causing a little wheel spin. did you drop the front sway bar? that would help the weight transfer a bit and plant the tires.
lata
tim
14.209@95.46mph
Best 60' 1.917
Old Sep 3, 2001 | 02:58 PM
DrStampede's Avatar
I have no wheel spin what so ever and as far as the front sway bar It has to stay in since the car is more of an autocross car
Old Sep 3, 2001 | 11:21 PM
I believe what NJ SPEEDER means is that you can just take the endlinks loose, and the leave the sway bay in place. This is what I did when I ran my RS. It made a signinficant difference, and since it's only 2 bolts you have to take off, and you can take them off with (2) 1/2" wrenches, I have to say it's definetly worth the 5 mins worth of work you'll have to to do.
Bassett Racing
Old Sep 4, 2001 | 11:04 AM
DrStampede's Avatar
I see whaat your sayen now. I guess i'm going to have to give it a try before i go out to the track next time.
MustangBeater20
Oct 29, 2022 09:20 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
midias
Aug 22, 2015 01:42 AM
gta power
Aug 13, 2015 06:15 AM
Exxon Limited
Aug 9, 2015 08:13 PM
