Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Lca angles
Old Jun 21, 2012 | 01:44 PM
91_B4C_RS's Avatar
Car: 1991 B4C Camaro RS
Engine: 370 lsx ls3 heads victor jr w/carb
Transmission: TH400 w/brake coan 8"4500-4800 stal
Axle/Gears: Moser 9" locker w/ 4.11's
Lca angles
I have lcarb's on my 9" rear ii have aleays ran them in the lowest hole. My car is stock ride height in rear. At ride height with lca in lowest position i have 8* of angle from rear end up to the body. What position are you all running on a drag race setup.
Currently my best 60' time is 1.513. Loioking to improve. My car seperates very well . I think too much. Would putting lca in stock location help me with getting more forward bite off the as too lift like i have now? Lca would be close to level. Also have a set of sriffer z28 springs laying around i could try whats. Your alls experience with lca angles and 60'
Foot times associated with adjusting thwm?
91 camaro
sfc's
Crossmember mounted t/a
th400 w brake
370 lsx
Trick springs up front 90/10 struts
50/50 shocks rear v6 springs
drag bar
28c10.5 et drags
Old Jun 25, 2012 | 06:38 AM
Shagwell's Avatar
Car: projects.......
Re: Lca angles
The more level they are, the more straight forward they are pushing instead of trying to lift the front end. - Whether or not you'll still have enough weight transfer to keep the tires planted at that setting comes down to many variables.
Try it and see how it acts. - Do you have a hole in between?
Old Jun 25, 2012 | 08:24 AM
91_B4C_RS's Avatar
Re: Lca angles
[QUOTE=Shagwell;5310743]The more level they are, the more straight forward they are pushing instead of trying to lift the front end. - Whether or not you'll still have enough weight transfer to keep the tires planted at that setting comes down to many variables.
Try it and see how it acts. - Do you have a hole in between?[
Gonna try middle hole see what happens
Old Jun 25, 2012 | 05:55 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Re: Lca angles
i've heard 2* upward is the ideal. mine are in the middle hole, and seems to 60' more consistently this way.
jbates346
Oct 21, 2015 01:50 PM
Jorlain
Oct 8, 2015 01:57 AM
mfp189
Sep 27, 2015 09:25 AM
FED 387
Sep 16, 2015 12:18 PM
Night rider327
Sep 16, 2015 02:20 AM
