Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
The sled went 10's!
Old Aug 21, 2012 | 10:54 AM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
The sled went 10's!
I was tickled to death this past weekend. I had made some changes to the suspension to help get the car to hook more consistently and I was rewarded with the car's first 10 second pass. I usually race at Captiol Raceway and the car would 11.0x me to death. They were closed for the past few weeks so I rode up to Mason Dixon which as about 700' higher in elevation. It went a 10.97@122.4 on the brakes at the finish line. Only bad thing is that I was dialed at 11.03 So I went home early but I was happy with how it ran. Can't wait to see what it will do at my home track which is only 50' elevation
Old Aug 21, 2012 | 11:02 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: The sled went 10's!
Thats a strong 383! Congrats
Old Aug 21, 2012 | 12:20 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
isn't it a great feeling! nice man!
so no buybacks? or was this several rounds in?
Old Aug 21, 2012 | 12:21 PM
gtpro700's Avatar
Car: 87 Firebird Formula
Engine: AFR headed SBC
Transmission: TKO 600
Axle/Gears: 9" Moser with 4.11's
Whats the motor combo look like? Is that NA run? Nice run either way man!
Old Aug 21, 2012 | 12:23 PM
Dialed_In's Avatar
It was second round. First round I went an 11.034 on an 11.03 dial. MOV was .0009
Old Aug 21, 2012 | 12:25 PM
Dialed_In's Avatar
6" rod, Mahle pistons, 10.8:1, lightly ported AFR 195's, Comp 236/242 cam straight up, port matched RPM Air Gap intake, 650 holley. Made 470 on my engine dyno.
Old Aug 21, 2012 | 02:10 PM
gtpro700's Avatar
Are the AFR 195's eliminators or the older style ?
Old Aug 21, 2012 | 03:34 PM
Dialed_In's Avatar
They are the older style.
Old Aug 21, 2012 | 05:29 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
10+ years ago I was 12-14 seconds. I know what it's like to break through all those barriers. My next one is to get below 9.0 which should happen as soon as I can get to the track.
You're at 10.9 now. Getting down to 9.9 isn't as easy as it sounds. Be happy to stay in the 10 second range. It's cheaper to race there.
Old Aug 21, 2012 | 06:18 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
Congrats!! Must have been that alternator bracket
Old Aug 21, 2012 | 06:20 PM
jg04222's Avatar
Car: '82 Z-28
Engine: 355
Transmission: TH-400, 8" ATI MRT
Axle/Gears: Moser 9", 4.56's
Congrats! If I ever make it to Capitol and you're there I'll be sure to say hi.
Old Aug 21, 2012 | 06:30 PM
Dialed_In's Avatar
Yup. I think that's what did the trick!
Old Aug 21, 2012 | 08:32 PM
Ice cold spit's Avatar
Car: 91 Camaro
Engine: 383 carbed/headers/nitrous
Transmission: th400
Axle/Gears: Chevy 12 bolt w/411 gear
Congrats on the run I have a similar setup what type of headers and exhaust did you run the 10 with
Old Aug 21, 2012 | 09:52 PM
87_TA's Avatar
Nice Run and congrats on the NPB! That is a good feeling.. First time I hit 10s my Father hugged me for first time-I was probably 20 years old - It was Awkward and never happened again.. lol.. 16 years later I get a thumbs up that we are both OK with.
Old Aug 22, 2012 | 07:47 AM
Dialed_In's Avatar
Hedman 1 5/8" longtubes with Edelbrock SDT mufflers.
Old Aug 22, 2012 | 07:58 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Kinda surprised the car is as heavy as 3500-3600 lbs with 470 hp on engine. Seems way low hp for that trap speed. I figured my 383 was 500 hp and at 3450 i went 119 mph but gear and converter werent 100% optimized for the combo either. Worked better with a nitrous shot . I think in great air i would have had 121 mph
Old Aug 22, 2012 | 08:31 AM
Dialed_In's Avatar
...with 470 hp on engine. Seems way low hp for that trap speed.
Could be higher, dunno. Every dyno reads different. I'm sure ours read a bit low as every engine that comes off of it runs better than it should. Dynos are a tuning tool more so than an accurate measure of HP/TQ. It also maps out the powerband which makes it a lot easier to select the ideal converter, tires and gears to make best use of the power available. Short version? It's all about the right combination.
Old Aug 22, 2012 | 10:10 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
True that combo is working just seems that the numbers are abit off from most others i see dyno'd but you are right dynos are a tool. Not all the same. What matters is et and traps and you have it worked out
Old Aug 22, 2012 | 10:50 AM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
What gears, converter and tires (diameter)? What RPM are you crossing the stripe? Trying to figure out where I'll be with my combo and the soon to arrive 4800 ATI.
Old Aug 22, 2012 | 10:52 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Congrats!!
Old Sep 8, 2012 | 10:30 AM
86iroc2try's Avatar
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
way to go...proves that smaller heads and carb are better for heavier cars...youre making steam in the first 1/8 mile...thats how you can run that fast. very well done.
i was supposed to race at capitol today...rain on the way keeps me sitting here playing on the computer. ill say hi if i see you down there someday!!
Old Nov 4, 2012 | 09:20 AM
Dialed_In's Avatar
Last race of the season at Mason Dixon yesterday. In the good air the car went three consecutive 11.74x's at 127.4mph. Track was hooking good considering how cold it was. The 60's were all 1.44x. Car is deadly consistent.....just need a driver HA
Old Nov 4, 2012 | 09:21 AM
Dialed_In's Avatar
TH400, Hughes ST3500 off the shelf, 3.73's, 28" tall M/T ET Radials.
Old Nov 4, 2012 | 11:11 AM
RatPoisonZ28's Avatar
Engine: Solid Roller 406 SBC
Transmission: RMVB TH400
Axle/Gears: Stock Ten Bolt 3:42 Gears
Congrats on the awesome times. What's your front and rear suspension consist of?
Old Nov 4, 2012 | 11:22 AM
Dialed_In's Avatar
Lakewood 90/10's and Moroso trick springs. Spohn adj torque arm, fixed LCA's and 50/50's in the back.
Old Nov 4, 2012 | 11:42 AM
Sweet bro! Car looks good with that front end pointed up! I have KYB AGX's on mine and I'm fixing to buy some moroso tricks for the front. How many coils did you cut off? And any install tips? I took my SBC IROC out Friday open header and all for its first pass and got a 11.7 @120mph and crossed the 1/4 nowhere near redline on 16 inch drag radials. Pulling a 1.8 60 all night.
Good luck with going faster! Oh and what size front tire are you running too?
Old Nov 5, 2012 | 06:19 AM
ezstriper's Avatar
Car: 91 Z28
Engine: 6.0 LSX 88 Turbo, EFI E85
Transmission: Glide
Axle/Gears: Strange 3:73 9"
congrads !!!!! used to race there in the early 80's (capitol)!!!!! have no been there in years !!!! moved 25 years ago..so not so close anymore...keep digging !!
Old Nov 8, 2012 | 06:58 PM
JSTAZ28's Avatar
Car: ' 86 Z28 , '02 silverado HD
Engine: 406 , 6.0 L
Transmission: TH 400 , 4L80
Axle/Gears: 3.73 , 4.10
Good job ! My combo is very similar to yours but i haven't reached your level yet . I'll be at Budds Creek sunday to hopefully get closer to it .
Old Nov 9, 2012 | 09:03 AM
Dialed_In's Avatar
I can't remember for sure, but I think I removed between 1 and 1 1/2 coils. They were a giant pain in the butt to install because they're so much longer than the stock spring. My tip is to go to harbor freight and buy a cheap spring compressor. Once you get the spring in place you'll have to cut the compressor into a few pieces to get it out because once the spring is in place the coils are too close to get the tool out.
Old Nov 9, 2012 | 09:44 AM
mw66nova's Avatar
Engine: 7.0L
i just take the control arm off, and jack the control arm up as a unit...have a buddy help ya though, cause this can be tricky
Old Dec 16, 2012 | 12:36 PM
I put some trick springs on the car yesterday and cut 1.5 coils off and it slammed my IROC on the floor, so much so that the headers were hitting the ground. I now have the OEM coils on and I'm going to buy another set and put them in uncut. Wonder why it did that if I have an aluminum headed small block, no sway bar, aluminum radiator e fan, Harwood lift off cowl and battery out back. Any insight?
Old Dec 16, 2012 | 01:02 PM
mw66nova's Avatar
Engine: 7.0L
That's weird. Mine are cut 2 coils and wasn't on the ground like that.
Old Dec 16, 2012 | 01:07 PM
I bought them used. Seller told me they were used for a season and then he swapped to coil overs. Could it be they don't have any umph left in th em after a season? I'm on KYB AGX struts in front set on soft also.
Old Dec 16, 2012 | 01:19 PM
mw66nova's Avatar
Engine: 7.0L
It's more likely that they're not the right part number. Did you have to un bolt the a-arms to get them in or could you put them in by just swinging the a-arm out of the way? If the latter, than they've been trimmed way more than 1.5 coils. These things are TALL out of the box, and even with 2 coils city off mine, I still have to un bolt the a-arm.
Old Jul 24, 2013 | 10:24 AM
N.J.-SLICK-1's Avatar
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
Axle/Gears: 3.73 limited slip
Nice true pump gas combo, are you driving thistoand from the track?
Old Jul 24, 2013 | 10:51 PM
GreggymacZ28's Avatar
Car: 1984 camaro z28
Engine: sbc 383
Transmission: Th400
Axle/Gears: Moser 9", 4.11 gear
What is the lift on the cam in this motor?
Old Jul 24, 2013 | 11:39 PM
PhoenixFirebird's Avatar
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
Interested to know some more detail on this as well, although it's an old thread. What accessories? Factory rims or drag rims? Transbrake? I have a similar combo that I'm just finishing up. 11:1 385, Holley 750, Performer RPM, Dart Iron Eagle 200s, 224/231 Comp cam. Also about 3500 pounds race weight. 3000 stall, probably not enough, and a 3.70 gear.
Without the carb being fully tuned, I'm running 12 oh's - 12 teens in bad summer air. Still has A/C, mech water pump, power steering, and alternator bolted up. Need to pull the A/C, throw on the electric water pump, and it should be mid 11s with ease, especially in good air. I could only hope that with a bit more cam and converter I could hit what you've got there. However, my bracket class cutoff is 12.00, and the car isn't caged. So in reality, it's sitting perfect lol.
sled_fiend
Oct 5, 2023 07:18 AM
whitelightnin92
Oct 15, 2013 09:05 AM
sled_fiend
South Central Region
Mar 23, 2009 09:25 AM
sled_fiend
Mar 17, 2009 03:48 AM
