Dcarter21
close
- Join DateFeb 2012
- LocationWest point ms
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- CarUnder construction 91 camaro rs
- Engine305sbc soon to be 385sbc
- Transmission700r4 soon to be th400
- Axle/GearsStock 7.5 10drag bolt soon to be fa
- Liked:0 Times in 0 Posts
Im looking to see how much power and what type of times i can run with this setup. This is my first car build so if u see anywhere i can improve let me know. We really only have 1/8 mile around here hoping to get low 8s out of this set up that will eventually improve.
91 camaro rs t-top car
Umi weld in Sfc
Bmr trans crossmember snd adjustable torque arm the rest of the suspension is bone stock for now
Gutted interior
412 sbc arp studed 2 bolt main
Speed pro hyper flat tops 11.2:1 comp
Eagle 5140 sir 5.7 rod
Gm crank turned 10/10 and ext balanced rotating assembly
Procomp 210 cc intake 64cc com chamber2.02 1.60 valves
Comp camd xe284h cam
comp 1.6 roller rockers
Vict jr intake
Holly 850 mech sec this was my first dedicated race build so some things may be mismached if so let me know
TH400 trans 3000 rpm stall
Stock 10 bolt 3:73 with mini spool ( running it until it blows)
Elec water pump no altinator or power stering
Running on 295 50 r 15 street tires and eventually 275 mt
How much hp and tq am i looking at making and what 60' times and et's can i expect
Umi weld in Sfc
Gutted interior
Vict jr intake
I would say you're up close to 500 horsepower, maybe 475 and would imagine you should be able to run in the 11's with traction.
I had a friend that had a similar setup:
383, 10:1 compression, XE284 cam, ported Edelbrock heads and he went 11.6's at 118 mph in a 3000 pound truck.
Dcarter21
close
- Join DateFeb 2012
Thats about what i was guessing power wise im in the process of building the car and trying to get some input on it
dedicated race car= 8" 5000 stall...
Dcarter21
close
- Join DateFeb 2012
Why do u recomend a 5000 rpm stall for an engine that will only be shifterd at about 6200 rpms. Which is already pushing the limits of my ext balanced stock crank and a 2 bolt main block. 10s would be nice which would equate to low 6s in the 1/8th but i also belive that wold be a bit optimistic how well i can get my 10 bolt to hook up.
10 bolt + 412 =
I doubt you will get one clean pass with a good hookup without having guts of it scattered. It will prob last a little bit since you wont hook with those tires.
With those tires I would think you will be in the high twelves.
