25 years ago so barely remember.
11.70s with 170hp in a 1400lb VW drag bug.
Good bracket race car, won a few hundred bucks with it.
1987 Buick GN
276" v6 with twin 58mm turbos
11.44 @ 125 with 15lbs of boost.
my first 11 sec pass was with my chevelle back 2001.....but last sunday went 11.53@115 on my 90 ta 1.52 60'', 10.21@129 on 150 shot(not tunned yet)
motor 383 eagle rot assembly srp pistons, hsr intake 58mm tb, tfs wedge heads, moser 12 bolt 3.73, 700r4 reverse manual with 3200 vigilante converter, 28x11.5 et street dot, have 275x60x15 mt dr that i want to try out.
going to try my lock up switch next time half way thru 3rd gear, should improve...if the trans stays tougether..lol
and i drove from my house to the track....1 1/2 hours away
im putting it on the trailer next time....just in case
skinny z
close
- Join DateDec 2005
- Location53.0907° N, 113.4695° W
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Liked:885 Times in 733 Posts
Was that at TMP?
Quote:
Originally Posted by skinny z
Was that at TMP? yup....there is rumors that an arm drop style drag racing might be happening at the oshawa airport this summer
skinny z
close
- Join DateDec 2005
Quote:
That'd be a shot in the arm for my old home town that's for sure but it's a tough one to get over all the hurdles. Good luck.Originally Posted by nossbc
....rumors that an arm drop style drag racing might be happening at the oshawa airport this summer Having said that, Smith Falls has their 1/2 mile event again this year so you never know.
http://racetherunway.com/
1987 Berlinetta; 3100lbs with me in it
396 BB
TH400
4.10 10 bolt 9x30 M/T ET drag
footbrake/two-step
11.98/115mph
Budds Creek, MD 2010
No power adders!!!
the new car is faster...
396 BB
TH400
footbrake/two-step
11.98/115mph
No power adders!!!
3100lbs...that's pretty light man!
11s someday..
Quote:
Cubic inch:370 ls motor
Power adder: no
Trans:borrowed powerglide
Gear:4.11
Weight:3350
Tire:Mickey Thompson 275/60/15 radial
Altitude:2424'
Trailer:Yes
this motor ultimately went 10.7x's once tuned and a proper trans/converter was in so this probably isn't a fair comparison.
i built a simple 10:1 355 with an xe274h and some 113 casting heads several years ago. i had problems with it and never got it dialed in, but that combo was pretty quick for what it was. i went 12.16@112mph, nowhere near optimized.
i seen videos of this run on youtube sounds great man! its funny you talk about the 10:1 355 with the 274 and cast heads, last year i was running 12.81s at 110mph with a 268 High Energy and a 2000 stall converter Smog truck heads ported a bit.. i am hoping for 12.50s-12.60s this year went with the 268 Extreme Energy and a 2400.Originally Posted by mw66nova
ET/MPH: 11.69@118 on a soft "first-pass-of-the-combo" type passCubic inch:370 ls motor
Power adder: no
Gear:4.11
Weight:3350
Altitude:2424'
Trailer:Yes
Quote:
Originally Posted by purdyMWP
i seen videos of this run on youtube sounds great man! its funny you talk about the 10:1 355 with the 274 and cast heads, last year i was running 12.81s at 110mph with a 268 High Energy and a 2000 stall converter Smog truck heads ported a bit.. i am hoping for 12.50s-12.60s this year went with the 268 Extreme Energy and a 2400. the xe268 is a much better grind than the he268, you should pick up a good bit under the curve with that. a 3800-4200 stall would jump you right into the 11's though, i bet....so much being left on the table in the first 60' with that tight of a converter.
greggbruce
close
3rd pass off the trailer, brand new combo, 4100lb. '70 nova 454 single carb, no power adder, 4.56 rear gear, turbo 350 with flowmasters went 12.18, 12.01, 11.88, then was time to go home, did some tuning and stuff, felt WAY quicker..... ended up selling it in parts.... then got the 87 formula 350 with 30k miles to run 12.20's on street tires with a 406 tpi, no nitrous or anything....just that damn hypertec chip....(yuk). Wish I had that car back....
skinny z
close
- Join DateDec 2005
Quote:
What did it take?
Cubic inch.
Power adder.
Trans.
Gear.
Weight.
Tire.
Altitude.
Trailer.
It's interesting to see what it takes. Originally Posted by skinny z
So...What did it take?
Cubic inch.
Power adder.
Trans.
Gear.
Weight.
Tire.
Altitude.
Trailer.
I see light weight, bigger cubes and higher stalls as an overall theme so far. This isn't to say people are going fast otherwise, it's an observation from what's been posted.
I started this thread to educate myself a little as my fat Camaro with it's 350 is still more than half a second short of 11.99.
Carbed 350 (Vortec heads, XR276HR, Air Gap, 670 vac sec )
700R4 with 10" TCI converter than I foot brake to 2000 rpm
3750 lbs race weight
3.73 rear gear
26 x 10.5 ET Streets
Probably 500 - 1000' altitude density
12.7 @ 108 with a 1.70 60'
That was last years combination.
Better heads this year, slightly different cam in a new chassis but the weight is still up there.
So far, 1/8 mile is 8.07 @ 85.14 with a 1.8 60'.
Closer...
750 double pumper, and lose 250lbs and i bet it goes 12.20's. what does the converter flash to on the hit? this is closer to the actual stall speed. with that much cam, i'd be looking at 4000 minimum. cool thing is, with the 700r4, once up to speed, the converter will lock up and act just like stock.
skinny z
close
- Join DateDec 2005
I've moved up to a BG 750 although it's still vacuum (I value my MPG as much as my ET!)
It's a street car to be sure. I lost the GFX and power windows from the IROC but I've added Spohn SFCs to the Sport Coupe. I've even added about 30 lbs of Dynamat to better suit my long distance cruising. A Dana 44 instead of the 9 bolt adds a little heft too. It's still close to 3700 with my 200 lb rear in the seat.
The converter is another thing altogether. I have video from the chassis dyno that clearly shows the tach jumping to 4000 rpm when the pedal is mashed at 3000 rpm. Foot braking only gets me to 2000 rpm or so before it starts to creep. I didn't think my PB of 1.7 flat (60') was too bad but I think there's more. There'll have to be if I want to go faster.
http://s1123.photobucket.com/user/kd...Dyno1.mp4.html
am i one of the only 3rd gens on here that weighs 3260 with me in it? where is all this weight coming from folks
well, you look like a pretty small guy on your vid. i can get down to 3300lbs with me in the car, but i'm 300lbs man. normal race weight for me is 3450. you start adding safety equipment, beefy rearend and trans, and the weight is easy to pour on. way back when i was still DDing my car, i got it down to 3090lbs with me in the car, but that was with before the roll bar, 9", and i was only about 240lbs back then.
Quote:
FWIW, i got better mileage with a mechanical secondary than with a vacuum secondary. my theory is that since you can actually feel the secondaries under your foot (has it's own return spring on the shaft, you can feel the tension get heavier) that you have a better feeling of when you are into the secondaries and when you're not. the vacuum secondaries open on engine demand, so it's easier to get into them if you're getting into traffic or something.Originally Posted by skinny z
I've moved up to a BG 750 although it's still vacuum (I value my MPG as much as my ET!) Junior Member
Quote:
Yeah that's True i weigh 145Lbs and my back seats Are out heater Core is out light weight Mini starter..Etc..Originally Posted by mw66nova
well, you look like a pretty small guy on your vid. i can get down to 3300lbs with me in the car, but i'm 300lbs man. normal race weight for me is 3450. you start adding safety equipment, beefy rearend and trans, and the weight is easy to pour on. way back when i was still DDing my car, i got it down to 3090lbs with me in the car, but that was with before the roll bar, 9", and i was only about 240lbs back then. Junior Member
Quote:
Yeah i am hoping to see a good gain just from the Cam itself 3800-4200 stall would be a little much on the street i think as i Drive it everywhere in the summer.. i think a 3000 stall would be as much as i would wantOriginally Posted by mw66nova
the xe268 is a much better grind than the he268, you should pick up a good bit under the curve with that. a 3800-4200 stall would jump you right into the 11's though, i bet....so much being left on the table in the first 60' with that tight of a converter. Junior Member
i was running in the 1.9s with the 60 foot with the 2000 stall last year
