Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Enough engine for 10's?
Old Jul 14, 2013 | 10:05 PM
rlopez018's Avatar
Car: 89 Iroc-z
Engine: 355 chevy
Transmission: TH 350
Axle/Gears: Still the OEM 9 bolt
I got a 355 with eagle rods, 13.3.1 compression, custom cam comp cams, 312-322 duration, 630- 630 lift, track 1 heads, roller rocker arm 1.5, victor jr intake, 5500 rpm converter, 350 tranny, msd box 6al, long headers, 3.70 gears for the moment, i got a 12 bolt already to put on it with 4.56 gears, can i run 10's second with that? I got before, flat pistons, double hump heads full porting, lunaty cam 292-302 duration, 550-571 lift n the same converter & tranny & 3.70 gears & run 12.23 at 107.56 miles on the 1/4 mile & 7.67 second at 96 miles on the 1/8 mile.
Old Jul 15, 2013 | 03:23 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Enough engine for 10's?
Possibly. ...go find out!
Old Jul 15, 2013 | 03:25 PM
86iroc2try's Avatar
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
depending upon the weight of the car and if the trans and converter are any good...i wouldnt see 10s being out of reach.
just hope the ring package has a good seal (1-2% leakdown most)...and it should roll
Old Jul 15, 2013 | 03:28 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Whats the .050 numbers on the cam? 312-322 seems alot of advertised duration for a 355. This thing will need to turn alot of rpm with a large cam and track one heads, but if light enough it should get there. Sounds like a possible 600 hp engine. Thats enough
Old Jul 15, 2013 | 03:31 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
This worries me. Is that a typo? 96 mph 1/8 but only 107 in the 1/4? The et lines up but mph doesnt. Should be 86 mph there i think
Old Jul 17, 2013 | 08:10 AM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
^^^ I was thinking the same thing...
Old Jul 17, 2013 | 04:15 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
yeah, only 10mph gain on the backend indicates a problem for sure.
Old Jul 21, 2013 | 06:46 PM
rlopez018's Avatar
Car: 89 Iroc-z
Engine: 355 chevy
sorry guys for the confuse on the miles but is true, may cause the i got a 275/50r15 is a lower tire and before finish the 1/4 mile the engine dont pull anymore, the tall rpm with the first engine is 6500 rpm, also is very straight motor, without msd, short headers, again the first engine, stock crankshaft & rods & cast flat pistons .030 over, lunaty cam 292-302 adv dur- DUR .050 256-268 Valve lift 550-571 Lobe sep 106/102 rpm range3800-7200, heads full porting 186 casting 2.02 1.60 valves, crane rocker arm 1.5, victor jr intake 750 cfm carb, 5500 tall converter, 350 tranny n 3.70 gears, new setup is a forged crankshaft, eagle rods, 13.3.1 compression piston, track 1 heads 2,080 & 1.600 valves, comp cam custom adv dur 312-322 dur .050 276-284 valve lift 630-630 lobe sep 107 rpm-6200-8500, same rocker arm but 7/16 bolt, same intake, 850 carb, msd this time & the rear end coming 12 bolt with 4.88 with new tall tires 275/60r15 drag radial, same converter 5500 rpm.
Old Jul 21, 2013 | 06:51 PM
rlopez018's Avatar
Car: 89 Iroc-z
Engine: 355 chevy
i call comp cam and i give what i want for my new setup and that the cam they recomended, i ask a friend last friday n tall me the lift is to low for that compression but he say i can put 1.6 rocker arm to put up the lift
Old Jul 22, 2013 | 01:08 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I think your cam is way to big for that combo and you need to reconfigure the tire/gear size to better fit the power band
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
