what should i run
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
what should i run
1986 IROC-Z, 5 speed, 350 L98 tpi swap, zz4 cam, t-top. 3.73 gears, boxed lca, adjustable PHB, belltech sways, eibach sportline hurst short throw. slp headers, to slp lm1, no cats, EGR delete, 18x8 255/35/18 front 18x9 275/35/18 rear BFG super comp II
i plan on making my first passes this week. im thinking in the mid to low 14s, this is the 1/4 mile.
tips, pointers, words of encouragement are appreciated!
Engine: 355
Transmission: 350
Axle/Gears: 342
Re: what should i run
Frist times to the track generally don't go as planned but don't be mad at the results its just a starting point to build on.
Car: 1987 Trans Am
Engine: 355 tpi
Transmission: 5 speed
Your cars combo may get you into the 13 sec range. Watch those hard launches that T5 may not like it or hard shifts that you need to get good #. But if this is your first go at racing don't expect better than mid to high 15s , The more you do it the better your times should be. Just keep us posted and show your time slips from your outing.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
those tires are going to fight you pretty hard. the combo will go 13's with traction. of course traction and a t5/10 bolt combo typically spells disaster one way or another.
remember to have fun.
welp never got there this week starter/battery trouble, next Wednesday we should have some results
Engine: 7.0L
Told ya. Get that sixty down in the 2.0 range and jump into the 13's easy.
eightsixseven
Dec 16, 2024 01:50 PM
Fast355
Dec 2, 2016 06:33 PM
