Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
5 point Roll bar possible?
Old Oct 17, 2013 | 08:06 PM
GreggymacZ28's Avatar
Car: 1984 camaro z28
Engine: sbc 383
Transmission: Th400
Axle/Gears: Moser 9", 4.11 gear
I've been looking to put a roll bar into my Camaro, and have been unable to find anywhere that builds a nice 4 point roll bar, or a 5 point with a swing out for the door bar. I am just trying to be able to go quicker than 11.49, not looking for this car to enter the 9's so anything more than a 5 point will be over kill. I have looked at s&w and other places people recommend, however I have been unable to find anything that is competition legal and not a roll cage.
Any help would be appreciated, thanks guys.
Old Oct 17, 2013 | 08:31 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Re: 5 point Roll bar possible?
competition engineering makes a 6 pt, as does s&w. i've used both and they're both nice. if you don't want the passenger door bar in, don't put it in. if you want to add a swingout, add a swingout, lol.
Old Oct 17, 2013 | 08:40 PM
Engine: sbc 383
Transmission: Th400
Okay, I never saw the 6 point by s&w. I saw they are popular for thirdgens but I was only able to find their 8 and 10 point cages. That will work then! Also, are their door bars welded to the 4 point already?
Old Oct 17, 2013 | 08:47 PM
mw66nova's Avatar
Engine: 7.0L
no. all the bars are cut long and are custom tailored to the car and driver since there are rules on door bar height concerning your shoulder to elbow location, helmet to main hoop location, etc.
Old Oct 17, 2013 | 11:35 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
To run quicker than 11.49, you need a minimum of a 5 point roll bar. A 4 point is a street bar and not legal for competition below 11.49. Most people who install a basic roll bar, install a 6 point since it provides a bit more protection.
To make getting in and out of the car easier, install swing out bars. If installed properly, it won't affect your ET limit and a 6 point bar, even with swing outs, is good to 10.0.
S&W is probably the best place to source out a roll bar.
FYI. A basic roll bar (6 or 8 point) is entirely made from 1-3/4" tubing. Although minimum spec is 0.118" wall thickness, it's normally sold in either 0.134" ERW or 0.120 DOM mild steel. You don't need CM tubing. Very inexpensive kits use tubing that's less than 0.118" wall thickness and can fail a tech inspection if someone ever decides to test it. It's unlikely a basic 6 point roll bar will ever be tested since it doesn't require a chassis cert but it's your life it's protecting.
When making a full cage, the largest tubing used is only 1-5/8" but you also have a lot more tubing in the car in various sizes.
S&W catalog page for roll bars. You need to contact them to order one specifically for your car. The only difference between a 6 and 8 point roll bar is the diagonal tubes under the main hoop that go down to the driveshaft tunnel. You don't have to install them if you don't want to.
http://www.swracecars.com/Files/SW-R...ol-31-Pg15.pdf
The other source for third gen race parts is Ed Quay
http://www.edquay.com
J-money
Jan 4, 2019 09:45 AM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Lanz06
Sep 14, 2015 07:16 PM
Fronzizzle
Sep 8, 2015 12:10 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
