Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
What should I run
Old Oct 21, 2013 | 11:42 AM
TreDeClaw's Avatar
Car: 1983 TA WS6
Engine: 357 (5.7L)
What should I run
350 junkyard bored 40 over
Cam:
cam lift: int: .298 exh: .298
valve lift: int: .447 exh: .447
lobe ctr: int: hyd exh: hyd
sae duration: int: 291 exh:291
.050 duration: int: 223 exh:223
sae timing: btc:30 abc:81 bbc:78 atc:33
.050 timing: btc:1 abc:42 bbc:49 atc:-6
Heads:
202 int.
160 exh.
Edelbrock RPM Air Gap intake manifold
Edelbrock 750 cfm carb
700R4
1987 TA manifolds, otherwise stock all the way back
3.23 gears posi rear
Ws6 suspension 4 wheel disk.
Street tires
AC delete
Around stock 3,200 Lbs
Old Oct 21, 2013 | 11:53 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: What should I run
What compression
Heads:
202 int.
160 exh.
This means nothing without a casting or model number
Why such a big carb for a small cam? This will make you slower
700R4
Stock stall?
OUCH
Not enough info to guess but I will try.
Somewhere between a 14.5 and 18.5
Are you using this cam?
http://www.summitracing.com/parts/hr...make/chevrolet
Old Oct 22, 2013 | 07:56 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
we really need more information man. cylinder head selection is a big deal. just cause it has a 2.02/1.60 valve combo in it doesn't make them good. i'm guessing it has a stock torque converter in it as well. just a WAG, i'm going to say 15.3ish, maybe slower.
wouldn't take a terrible amount of money or effort to get it in the the 13.9 range.
what is your goal?
Old Oct 22, 2013 | 03:18 PM
Cosmik Debris's Avatar
14.27634 if you can do 1.9 60ft.
Old Oct 22, 2013 | 05:29 PM
TreDeClaw's Avatar
Car: 1983 TA WS6
Engine: 357 (5.7L)
what is your goal?
EDIT: 69 corvette double hump heads
My goal for this setup is 14.00 but really a 13.9.
Its a 325-350 hp, 345-375 tq motor
With full exhaust and a torque converter I would expect 13.5-13.7
Old Oct 22, 2013 | 05:32 PM
mw66nova's Avatar
Engine: 7.0L
says who? serious question, not a stab
Old Oct 23, 2013 | 11:02 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Heads, cam, tires, and gears are holding this combo back.
As it sits I say high 14's/low 15's, low to mid 90's for mph. Drag radials and steeper gears will get you closer to your goal, but the camshaft and heads is going to have a hard time making 350 horsepower imo.
Old Oct 23, 2013 | 01:25 PM
TreDeClaw's Avatar
Car: 1983 TA WS6
Engine: 357 (5.7L)
The machinist at the shop, and the rest of the car enthusiasts who I have talked to at shows.
It makes sense to me, the cam is rated 350 hp and tq. I expect to be lower with the stock exhaust and converter right now.
Old Oct 23, 2013 | 02:23 PM
A camshaft can't be rated for a certain horsepower level there are just too many variables (compression, displacement, cylinder head flow, etc).
A 350HO crate engine from GM makes 330 horsepower 380 ft lbs of torque with open headers, better heads (Vortec), and arguably a more modern camshaft.
You're asking your question in the right spot, the drag racers know what it takes to make horsepower and run a good ET/mph. In my experience, at car shows everyone is "making at least 400 horsepower", have you ever seen an event where those guys find out what their cars will run. I have and it's not pretty
Old Oct 23, 2013 | 02:48 PM
mw66nova's Avatar
Engine: 7.0L
^^^i thought it was "at least 600 hp" nowadays.
car shows is not the place to ask.
i think that with headers and proper tune that combo can make 300ish flywheel hp. this CAN be enough to get you to your goals, but it needs a converter built for it like "whoa", and needs more gear, definitely sticky tires, and go ahead and through sfc's lcarb's at it to be good.
Old Oct 23, 2013 | 03:07 PM
midias's Avatar
That cam is about the same as the 327 325hp cam. Although those are 1960s hp so that would be a 250 - 275hp engine today.
Old Oct 23, 2013 | 03:09 PM
400 at the wheels, 600 at the flywheel, losing 200 horsepower through the 2" flowmaster 40 series mufflers
Old Oct 23, 2013 | 03:17 PM
mw66nova's Avatar
Engine: 7.0L
oh of course, what was i thinking
Old Oct 23, 2013 | 03:23 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
...but I can still do the $100 bill trick with it though!!!!
Old Oct 23, 2013 | 04:11 PM
TreDeClaw's Avatar
Car: 1983 TA WS6
Engine: 357 (5.7L)
The guys who set up my engine parts put together some good working parts, I should be 10:1 compression.
Please tell me how that makes any sense.
Old Oct 23, 2013 | 04:24 PM
midias's Avatar
Because in the 1960s they measures gross HP so a 1960s 350hp engine was 350 gross hp. Now they measure Net HP so a 350 gross hp engine is ~250-300 net.
Those engines were over rated by today's standards by 15-30%
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
