Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
New engine running...How fast will it go?
Old Jun 19, 2014 | 11:44 AM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Transmission: POWERGLIDE
Axle/Gears: MOSER 12 BOLT 5.36 1/8 MILE ONLY
New engine has been installed and plan on taking car to track Saturday. Anyone want to guess what car should run? See car specs below.
Weighs 3400 with driver
383 with AFR 195 Hyd roller 540 lift 10:5 comp
700R4 3000 stall 10 inch converter
Dyno Don 1 3/4 shorty headers into Hooker cat back
275/60 15 M/T drag radial
850hp carb no spacer flat hood
4:27 Axle
I will keep you posted with results!
Old Jun 19, 2014 | 07:06 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: New engine running
Depends on traction but high 11's should be obtainable. Specs are very similar to my old 383 but I also raced at altitude. Take that into effect and mid 11's may be a closer guess.
Don't be disappointed if you can only manage 12's. Then again, it may run great and give you a 10 second timeslip but I highly doubt it.
A guess is just a guess. How well it hooks and gets down the track will be what it runs. Any number of things can make it run less than expected. First day at the track will give you a bunch of baseline runs that you can work with to see what works and what doesn't.
Old Jun 19, 2014 | 07:17 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Thank you for the response.... My goal is to run 1150s with big speed. I am done with the days of rollbars and seatbelts that have to be replaced every two years...lol... I don't get out that much And it seemed like I was always replacing them. I will keep you posted with the results if I get out.
Frank
Old Jun 19, 2014 | 10:13 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I know that feeling.
I installed new belts in my car in the spring of last year and I haven't had a chance to use them yet. If I don't get the car ready to race this year, they get sold off this fall as "Installed but never used but the date code has expired". Last expired set I sold went to someone with an offroad VW bug.
I can sell off the expired belts for about half the cost of new ones. RCI Platinum belts are a good deal if you live in the States. You get to send them back for recertification once. In Canada, the shipping cost back and forth across the border eats up any savings you would get from the recertification so it's cheaper to just buy new belts.
Old Jun 22, 2014 | 07:48 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Made it out yesterday and ran pretty well. I attached a picture of one of my passes (I am in right lane) I ran 11.59 @ 119 deep staged (shallow would be about a tenth quicker) one run during eliminations car was on a 11.53 pass (11.43 shallow) Did have one issue with slight stumble off the line. May be related to fuel issue. I will keep you posted.
Old Jun 23, 2014 | 06:45 AM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Re: New engine running...How fast will it go?
Get that thing to launch and you should see some 11.0's....
Old Jun 23, 2014 | 01:00 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Car built for 11:50 & slower class. I do not want to put a roll bar in and deal with updating seat belts or fire jacket. I've been down that road before and this car is not raced that much but I do drive it on the street. I think if stumble is gone its could go 11:teens in better air @ 122.
Old Jun 23, 2014 | 04:33 PM
91RamAir Formula's Avatar
Car: 91 Formula
Engine: 383 HSR
Transmission: 5th 700R4
Axle/Gears: 3.89
Man I'm leaving a lot on the table basically same setup only 8.5:1 and 3:73's best of 12.6@107 great numbers.
Old Jun 23, 2014 | 09:43 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Thanks...what is your set up? Seems off even with lower compression and gear should still be in the 11s
Old Jun 23, 2014 | 11:49 PM
Car: 91 Formula
Engine: 383 HSR
Axle/Gears: 3.89
383 AFR 195's, 1 3/4 hooker long tubes, cc306 .544 .577 lift 236 244 @.050 (old grind)
10" 3500 stall 700R4 on et street radials. Have not been to the track in a couple of years though. Holley Stealth Ram 30lb injectors.
Old Jun 23, 2014 | 11:50 PM
Car: 91 Formula
Engine: 383 HSR
Axle/Gears: 3.89
what is your suspension setup?
Old Jun 24, 2014 | 06:36 AM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
What is weight with you in car?
Old Jun 24, 2014 | 06:41 AM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
The only changes made to suspension are 6 cly. front & rear springs and rear air bags.
Old Jun 24, 2014 | 11:28 AM
Car: 91 Formula
Engine: 383 HSR
Axle/Gears: 3.89
just under 3400
Old Jun 24, 2014 | 11:29 AM
Car: 91 Formula
Engine: 383 HSR
Axle/Gears: 3.89
I think my compression is hurting me the most and compounded by big cam. my cranking compression on a comp gauge is only 135psi
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Fast355
Dec 2, 2016 06:33 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
