Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
ATI PG thoughts?
Old May 9, 2022 | 03:47 PM
MIB4X4's Avatar
Car: 1986 Camaro
Engine: 632 BBC
Transmission: TH 400
Axle/Gears: Ford 9in 4.34
ATI PG thoughts?
Looking to shift from my Art Carr TH400 to a PG and was looking at ATI and wondering what the thoughts on them were. I am installing a 632 BBC that made 1043 hp and 850 ft lbs trq on the dyno. I am looking at their High Impact Pro Glide to allow room for improvement. ATI Powerglide - High Impact Pro GlideŽ Drag Racing Transmission (atiracing.com) but like everyone I want reliability and sustainability.
Old May 10, 2022 | 12:02 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: ATI PG thoughts?
My PG is still an OEM case and majority of the internals are still OEM. There are a few aftermarket parts inside to replace the parts that normally break but I still run OEM 1.76 gears even though some 1.80 straight cut would be better. I could easily spend $5000 for an all out aftermarket PG capable of working with 2000 HP but until mine breaks, I don't need it.
With transmission and torque converters, you really do get what you pay for. Inexpensive parts are not quality parts. Expect to pay around $1000 for a converter to match the engines powerband. The dyno chart will make picking the correct stall a lot easier.
With a high torque engine for drag racing, a multi speed transmission is not really required. You'll have more than enough torque to get you off the line with the first gear of a PG no matter what the ratio and with only one shift, it improves consistency.
Old May 10, 2022 | 02:40 PM
MIB4X4's Avatar
Car: 1986 Camaro
Engine: 632 BBC
ALKYIROC, thanks a ton for the info and putting my mind at ease with the PG choice. Will work with the transmission manufacturer to ensure correct torques converter.
Whitechevy92
Oct 7, 2015 12:15 PM
RSluvr
Camaros Wanted
Jun 3, 2007 11:03 AM
smokumZ28
Oct 5, 2006 09:43 AM
