Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Probable 1/4 time??
Old Mar 12, 2002 | 02:14 PM
84TransAm's Avatar
Probable 1/4 time??
All the information is here:
http://84transam.freeservers.com/engine.html
I'm thinking low 15's maybe high 14's.
Old Mar 13, 2002 | 12:29 PM
howsci's Avatar
Just go to the track. there are two in richmond. Virginia Motorsportspark is the better one. I think they have test and tune every weekend. but i'd gues high 15s or low 16s nothin a modded integra couldn't handle
Old Mar 13, 2002 | 06:08 PM
84TransAm's Avatar
don't sound so smug
Just remember a stock 86 Caravan would have no problem dispatching your 88 5th Avenue.
Be glad you've obtained a 305.
Old Mar 13, 2002 | 10:30 PM
Alan84TA's Avatar
I'm running 200 RWHP (dynoed it) which would be about 240 flywheel, with my '85 L69 with a T-5 and 3.73 posi, a few basic mods... My best run so far is 15.0 @ 96mph and that was with a 2.4 60ft time. I just got some ET streets that should put me into mid 14's I also have some roller rockers and intake that should help some too.... I've seen a couple people running low 14's with the same setup.... A lot of it is tunning and practice..... (and weight reduction) I ditched about 150lb of crap and that always helps too... my first run ever bone stock was 16.3, but I way babying it...
Old Mar 17, 2002 | 02:48 PM
jamespizza's Avatar
it is known that every 100lbs of weight is equal to 1/10th of a second in quarter times.
or so i am told.
-jim
Old Mar 17, 2002 | 03:24 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If both cars are set up identical, HP, gearing etc, a 3200 pound car will be quicker than a 3500 pound car.
Even fast cars use the 100 pounds for a tenth of a second formula. Removing 1000 pounds is like adding about 100hp.
Vintageracer
Jan 10, 2020 05:33 PM
evilstuie
Jan 9, 2020 08:29 PM
midge54
Dec 27, 2019 04:14 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Infested
May 22, 2018 11:56 PM
