Pacific Northwest Region Regional discussion board for WA, OR, ID, and BC.
in need
Old Jan 14, 2011 | 07:51 PM
frankinmaro's Avatar
Car: 87 Frankinmaro
Engine: ZZ4 short block 67 327 462 castings
Transmission: TH350-c out of Y body
Axle/Gears: 97 4th gen Torsen 3.23
in need
Im hunting for 90-92 spindles for brake upgrade hit me up if ya all got any lying around. thanks
Old Jan 14, 2011 | 10:40 PM
AmorgetRS's Avatar
Re: in need
Why 90-92?
Old Jan 14, 2011 | 10:50 PM
Car: 87 Frankinmaro
Re: in need
x
Old Jan 14, 2011 | 11:13 PM
AmorgetRS's Avatar
Re: in need
You can use the earlier ones without problem....
Old Jan 16, 2011 | 01:24 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: in need
Originally Posted by frankinmaro
mid year 89 GM started to cast the spindles thicker do to the 1LE brake upgrade it allows modifying without compromising the structure(early spindles can work to but ya need to be right on with your cuts and redilling of the mounting holes). Im finally getting around to doing my Ls brakes
I had no problems modding the spindles I acquired from the junkyard for C5 calipers, and I used a hand drill, no press. I forget what year they were, but almost positive they were pre-89.
Old Jan 17, 2011 | 10:51 PM
Car: 87 Frankinmaro
Re: in need
picked up a set for $30 thanks for the pms and info
