As soon as the transit strike is over,im gonna sell my GTA and get either an 89 Formula 350 or an 89 GTA 350.Maybe if i find a good one for a good price a 91 or 92 Z28 because those look badass
1987 Trans AM GTA
305 5SPD
Hypertech airfoil
gutted maf
kn filter
High Flow Cat,
3"Walker pipe
Dynomax Super turbo Muffler
TB Coolant bypass
Lubricated by Mobil 1 Tri-Synthetic
1987 Trans AM GTA
305 5SPD
Hypertech airfoil
gutted maf
kn filter
High Flow Cat,
3"Walker pipe
TB Coolant bypass
probably go for the 89 Formula i gotta stick with my bird roots.Plus i wanna stay away from Speed density and stick with maf
1987 Trans AM GTA
305 5SPD
Hypertech airfoil
gutted maf
kn filter
High Flow Cat,
3"Walker pipe
TB Coolant bypass
1987 Trans AM GTA
305 5SPD
Hypertech airfoil
gutted maf
kn filter
High Flow Cat,
3"Walker pipe
TB Coolant bypass
lmao no matter what he gets he'll have to change his name
Of course if you get one of those 4th gen look alikes instead, you can change your name to:
GeoStormshadow GTA
GeoStormshadow GTA
Quote:
<font face="Verdana, Arial" size="2">Originally posted by Stormshadow GTA:
</font>
Why? The MAF used on 3rd Gens is not that good...it was the first try. Don't confuse it with the MAF system used on 4th Gens, its a COMPLETELY different system...but then there is OBD II. <font face="Verdana, Arial" size="2">Originally posted by Stormshadow GTA:
</font>
SD is definitely the way to go and it is not that hard to tune. It is the most defined ECM and lots of expertise on it. And when you do get SD tweaked ... hang on.
SD is a mystery to me,MAF is a lot less complicated ,plus i've seen all the calculations the comp has to make to determine airflow on SD with MAF it is simple.
1987 Trans AM GTA
305 5SPD
Hypertech airfoil
gutted maf
kn filter
High Flow Cat,
3"Walker pipe
TB Coolant bypass
1987 Trans AM GTA
305 5SPD
Hypertech airfoil
gutted maf
kn filter
High Flow Cat,
3"Walker pipe
TB Coolant bypass
</font>
Depends. It is easier to get SD exact due to its precise relationship between RPM/MAP and Volumetric Efficiency. Most guys that convert to SD from MAF find SD actually easier once they get the knack of it. Just takes a little time.<font face="Verdana, Arial" size="2">Originally posted by Stormshadow GTA:
</font>
For a basically stock engine or mild mods you are probably better off remaining with MAF. Big cams causes MAF problems and then there is the 255 gm/sec limitation. 383s max out at fairly low RPMs due to the 383s air needs. 350s can start to have problems with air flow if they have a big cam and spinning high rpms.
