Pacific Northwest Region Regional discussion board for WA, OR, ID, and BC.
will a v6 t5 work on a v8 if i get a t5 bellhousing from a v8 car?
Old Aug 2, 2001 | 10:45 PM
mark406's Avatar
you guys know if it will? id like to put a 5spd in my 82 transam,the 5spd is from my 89 firbird,also i know that it wont hold up to the amount of power my engine has so if i go easy on it wood it work?
Old Aug 2, 2001 | 10:50 PM
87RS402's Avatar
IIRC, the input shaft splines are different so you will have to use the V-6 clutch disk.
Old Aug 2, 2001 | 11:14 PM
mark406's Avatar
but will a v6t5 bolt up to a v8 bellhousing?thats wut i need to know.im sure i could get a high perf clutch disk for a v6,but i need to know if the v6t5 will bolt to a v8 t5 bellhousing
Old Aug 3, 2001 | 12:27 AM
Demon Z28's Avatar
Car: 2001 Camaro SS
Engine: Almighty LS1
you don't wanna do that
Bolt patterns are different, and I think the actual input shaft is different as well, but I'm not 100% sure on that...
not really a good idea to do
Old Aug 3, 2001 | 09:12 PM
Hunter Motorsports's Avatar
Car: Camaro Z28 1LE R7U
Engine: 5.0 TPI
Transmission: G-Force Dog-Ring T5
The length of the input shaft is different, so the transmissions will not interchange.
Your best bet if you are going to get a T-5 is an 88-92 World Class from a V-8 car, preferably from a Z28, cause they have a better 5th gear ratio. The World Class is the strongest version of the T-5 and the Sybchros are the most durable and effective. These gearboxes can be a bit tuff to come by, but they are worth the effort.
A properly built World Class T-5 can comfortably handle 400 HP and 400 Lb-Ft torque, if it is not abused.
Karl Hunter
Hunter Motorsports
Vancouver, B.C. CANADA
Old Aug 4, 2001 | 05:14 PM
Stormshadow GTA's Avatar
Hunter where are you guys located in Burnady,does your store have much for TPIs
1987 Trans AM GTA
305 5SPD
Hypertech airfoil
gutted maf
kn filter
High Flow Cat,
3"Walker pipe
Dynomax Super turbo Muffler
TB Coolant bypass
Lubricated by Mobil 1 Tri-Synthetic
Old Aug 5, 2001 | 01:38 PM
Engine: 5.0 TPI
Not a store. (Yet, hehe) Just me and my travelling road show, sort of. I run things from my house, but I usually have multiple projects on the go at various places around town including my place.
As far as TPI stuff goes I have a selection of parts, and many sources for the stuff I do not have. Let me know what you need and I can help you out.
Karl Hunter
Hunter Motorsports
AussiePr0nCar
Mar 6, 2020 04:04 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
Ragin'87
Jun 3, 2001 07:43 PM
ChrisFormula355
Dec 14, 2000 03:59 PM
