Pacific Northwest Region Regional discussion board for WA, OR, ID, and BC.
Car accelerated by itself
Old May 26, 2022 | 11:38 PM
egeoj10's Avatar
I was driving my 89 Camaro rs and then noticed it started to accelerate by itself. I tried hitting the break but could only bring it down to about 20mph as soon as I let go of the break it would start accelerating again. Managed to pull over and turn it off. When I turned it back on motor accelerated on its on while on park. Anyone know what could have caused this and or how to fix it?
Old May 27, 2022 | 12:14 AM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: Car accelerated by itself
Sticky throttle cable perhaps. Take off your air cleaner assembly and look at the throttle blades, are they open at all?
Old May 28, 2022 | 11:10 AM
egeoj10's Avatar
I haven’t had a chance to look into it, but if what you said was the case, what would that mean?
Old May 28, 2022 | 11:24 AM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Means the car would try to accelerate itself.
Old May 28, 2022 | 11:44 AM
egeoj10's Avatar
What I mean is how can I fix this issue
Old May 28, 2022 | 11:45 AM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Perhaps you could find priest to perform an exorcism.
Your return spring on the throttle is probably broken...
Old May 28, 2022 | 12:11 PM
egeoj10's Avatar
If the cable is ripped from the throttle would that be the cause?
Old May 28, 2022 | 12:18 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
You need to physically look at what's happening in the engine bay before the problem can be root caused. If you don't know what you're looking at, take pictures.
desanctis.dino
Mar 5, 2014 11:37 AM
Autumn219
Jul 12, 2013 11:27 AM
