Pacific Region Regional board for Pacific Third Gen owners.
Running auto-x May 29th
Old May 20, 2004 | 02:22 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
Okay, I finally broke down and have committed to running my car at the Solo II events this Saturday. I'll be entered into the F-stock category IIRC, and hope to have fun testing my car and myself! The suspension is bone-stock except for some end links, and Aquatread tires on 15 inch rims - the STOCK GTA rims are 16's with Gatorbacks, I think.
Old May 20, 2004 | 03:09 PM
3rdGenBlackBird's Avatar
Sounds good! How much did all that cost ya?
What are the requirements? I'm sure you need a helmet, and the basic drag race rule stuff, anything else?
How much tread is left on your tires? Might be a good excuse to upgrade. If not before the track, at least after your done rippin' up those meats!
Keep us updated.
Laters.
Old May 20, 2004 | 03:18 PM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
Good luck & let us know how you do
Old May 20, 2004 | 05:05 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Oh, no, the car CAME with those crummy rims and tires on it. Apparently, the previous owner thought that 15-inch tires would be way cheaper than 16's. Sorry, it's not that huge a difference. I'd like to find GTA rims here on Island, but everywhere I look, they're uber-expensive.
I know I got to have a helmet and there's a basic tech inspection to make sure my battery is bolted down good and the tires won't fall apart - basically, it's a make-sure-your-car-won't-fall-apart inspection. I'll have to stash all the loose crud in the wife's car while I run. I get four passes, so my times should go down as I learn the course.
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
