305 to 350 swap
Car: 1992 B4C
Engine: L98 5.7 liter
Transmission: THM 700-R4
IIRC, the two have very similar harnesses. It would be best to look at service manuals for both donor and recipient car and check the connector by the passenger kick panel...
I believe all the connectors are in the same location, as are the fuel lines. You will have to change fuel pumps though.......
HTH...
Robert
HTH...
Robert
There is a post on the forums here about re-pinning the L03 harness to Speed Density TPI, definately the way to go since you can re-use the stock harness. At that point you'd need a TPI fuel pump, 730 TPI ECM, the 350 TPI motor itself (Speed Density TPI, so 90-92 TPI, earlier TPI can be converted to Speed Density), TPI throttle body, the TPI fuel hardlines, and the correct cables for throttle and kickdown, etc.
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
Originally posted by 808RS
so would it be easier just to pick up a crate motor? cost wise and installation
Doing a motor and induction swap is a lot of work and quite expensive if you have to pay someone else.
Plus, you'll get upgraded suspension, rear end and brake components.
