Pacific Region Regional board for Pacific Third Gen owners.
SFC Installation
Old Mar 31, 2005 | 01:10 AM
3rdGenBlackBird's Avatar
SFC Installation
Who has SFC's on their car? Any good places to get them installed at a reasonable price?
I would attempt it myself if I had a welder and a lift, but even then my welds aren't anything to brag about....
Most exhaust systems don't get in the way, do they?
The two "big" projects for the 'bird this summer are SFC's and a new (y-pipe-back) exhaust. Looking at Spohn and Banks at the moment. Or Hooker- that aerochamber muffler <i>really</i> looks good.
Scott
Old Mar 31, 2005 | 06:58 AM
CrazyHawaiian's Avatar
Car: too many ...
I have a uninstalled set of Kenny Brown Supersubs, if you'd like to have a look see let me know. I'd also like to know where to get them installed, I've been meaning to get it done for a long time. Also need LCA and Panhard relocation brackets welded. Been waiting till its time to do interior so I can pull the carpet before taking it in. The suspension needs to be loaded while welding them on, so whoever does it has to have a drive on lift (or those ramps). I've heard the general rule is always SFC's first, Exhaust second. I do hear about fitment issues with SFC/Exhaust quite often on these boards.
Old Mar 31, 2005 | 08:21 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
I'll remember that, because I want SFC's for the TTA - t-tops and gobs of torque just don't seem to mix. I ws going to do the exhaust too, but that can wait until after the SFC's.
Old Apr 2, 2005 | 01:54 AM
1320 Right Ln.'s Avatar
exhaust clearance is gonna depend on which SFC's you choose. The ones that simply run straight down the sides of the car shouldn't give you any problems, but the S&W set-up on my 92 Z had major clearance issues. My old 89 IROC had the competition engineering ones that just go down the sides... I'm really not that confident that it's design was worth it, although it did make jacking up the car VERY easy
The S&W SFC's while pricey, were definately worth the effort to make them fit... easy for me to say cuz my dad did all the work haha. But i think they're the best design out there, torque arm mounts right to the SFCs. they connect the rear subs to the back end of the fronts right in front of the transmission crossmember. Having a 3 inch exhaust took up all the clearance and another bend had to be made in the piping to fit. Also you lose quite a bit of ground clearance, so the crossmember for the SFC's had to be cut and rewelded to make it straighter cuz it originally has a big dip for the exhaust to pass over.
hopefully this pic will make it easier to understand. It was taken before the exhaust was finished tho...
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
kairles
Oct 26, 2015 09:13 PM
gixxer92
Sep 1, 2015 04:32 PM
