92 Z-28 wiring diagram
Car: 92 Z/28
Engine: 355ci. /only connecting rods stock
Transmission: TCI Streetfighter auto
Axle/Gears: stock 3.23 :(
hey guys, i'm in the process of re-wiring my 92 Z/28 after putting in the new engine and switching to carb from the old TPI. the only wiring diagram i can find is in the haynes manual that i have, but i cannot find anything online. does anybody have different ones? tks
Car: '86MCSS
Engine: 396 .030"
Transmission: M20
http://www.diy-efi.org/gmecm/ecm_info/1227730/
This is purty much the EFI wiring diagrams. I dunno what else you'd be looking for. stew
Car: 92 Z/28
i'm having problems opening that for some reason.... i dont know.
my problem is that the colors of the diagram compared to the actual wires are all messed up and non-coordinating with each other. so, i'm tryin to see if theres other diagrams out there that might go along w/ mine. my wire harness was the original so they havent been switched around.
Car: 92 Z/28
i need the starting diagram. i need to know how many wires are supposed to run to the ignition switch, alternator, starter, etc, and where they run to
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
Glowsock
Jan 9, 2017 04:06 PM
louishenry
Aug 28, 2015 09:41 AM
