WTB:clutch pedal, and 2 pc flywheel for T5
Subscribe
Apr 30, 2005 | 09:43 AM
im doing a few projects, and i need a cluthc pedal for one of the projects, and a 2pc flywheel for an 88 T5.
(im located in minnesota)
edit: flywheel for a 2pc block!
May 1, 2005 | 01:34 PM
what does ttt stand for?
May 2, 2005 | 08:21 PM
To The Top....(Bump)...get it?
I got that 2pc flywheel for T-5....Nice shape, does not need to be cut. I went from a 2 pc to a 1 pc motor.
May 3, 2005 | 04:00 PM
Pedal assembly
I have a manual pedal assembly for $50 shipped. Also have complete hydraulic clutch setup and extra master and slave(no connector line.
May 4, 2005 | 02:31 PM
i just need the clutch pedal to finish the installation of the T56 into my car....
May 4, 2005 | 04:20 PM
As far as I know...and anybody step in here and correct me...from doing a conversion myself, you must replace the pedal assembly. You cannot just add a brake pedal to the automatic brake pedal assembly. For one, the automatic brake pedal is too wide to allow another pedal next to it nor do I think the bracket will allow another pedal to be mounted anyway. All I have ever seen for sale is the complete assembly.
May 7, 2005 | 08:25 AM
thats correct, sorry, i should have been more clear, i need the clutch pedal WITH the brake pedal assbly....
manual pedal assby?? as in NOT hydraulic?
when i said i needed the clutch pedals only, i meant i didnt need the hydraulic parts ie slave, master etc...
May 8, 2005 | 04:46 PM
I have a flywheel that would work for you.
I sent you an email.
Subscribe
