Parts Wanted 2006 Looking for something in particular? Ask here.
question!!!!!!
Old Jul 2, 2005 | 05:50 PM
badazz91FF's Avatar
Car: 91 Camaro RS
Engine: 362
Transmission: 5 speed
question!!!!!!
i need a flywheel or a bell housing cuz i am wondering if a stock 10 inch flywheel out of a early motor pre 80 with a 2 piece rear main will fit inside the stock bell housing on a 91 camaro
Old Jul 2, 2005 | 06:12 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Flywheel should fit being that chevy never changed the size of their bellhousings from the early powerglide years to present, or at least concerning Gen 1 smallblocks.....your only concern will be weather your present motor is a one piece or 2 piece rear main seal.....these are NOT interchangeable.......If you have a 2 pc flywheel you need to be bolting it to a 2 pc crank(pre 86).... it will not fit on a 91 block. A one pc flywheel(T-5) is available at most auto parts stores for around $160+......2 pc you can buy used(or new), I got one if you need it.
Old Jul 3, 2005 | 12:26 AM
badazz91FF's Avatar
Car: 91 Camaro RS
Engine: 362
g
what size is teh flywheel you have?
Old Jul 3, 2005 | 07:41 AM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Re: g
The 2 pc T-5 flywheel I have measures aprox 13" in Diameter.
I may be able to email you a pic. LMK
Old Jul 3, 2005 | 03:48 PM
badazz91FF's Avatar
Car: 91 Camaro RS
Engine: 362
will that fit inside my bell housing for my camaro i have a 91 rs with a t5?.....if it will i want the flywheel
Old Jul 3, 2005 | 06:52 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Dude, the flywheel will certainly fit inside the bellhousing(12 3/4 "). If your intention is to bolt it up to your 91 engine(1 pc rear main) then this(my) is NOT the flywheel for you, unless you already changed the motor to a pre 86 2 pc style.....If your engine is the original one for your car(91 Camaro), like I said this won't work for your application.
Old Jul 3, 2005 | 09:17 PM
badazz91FF's Avatar
Car: 91 Camaro RS
Engine: 362
i need the flywheel to fit inside my original bell housing for the 91 camaro the engine is a 77 camaro engine i know the one piece rear main is different thats why i need the one you have and i was asking if it would work
Old Jul 4, 2005 | 09:57 AM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Email sent with pics.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
