Parts Wanted 2006 Looking for something in particular? Ask here.
383 or a 396
Old Oct 11, 2005 | 09:09 PM
liteumup387's Avatar
Car: 1982
Transmission: 350
383 or a 396
im looking for a 383 0r a 396 located around illinois, i dont care if its a long block, short block, bare block or complete engine please help me out a little
thanks,
john
Old Oct 11, 2005 | 11:17 PM
57TUNED's Avatar
Car: 88 iroc
engine
i might be selling my engine out of my iroc motor run 11s on pump gas thinking about building a blower motor how much are u looking to spent
Old Oct 12, 2005 | 02:58 AM
XChris1632X's Avatar
Car: 83 Z-28
Engine: LG4 305
i have an 80-85 350 block bored .30 over and a cast scat 383 crank. lt1 rods they just have stock size pistons still on that need to be removed. vortec assembled heads and edelbrock manifold. and some of the bearings. if interested make an offer. i dont know the person responsible for doing the machining so clearances need checked and finish hone needs done to remove cylinder surface rust before assembly
Old Nov 4, 2005 | 07:59 AM
Deimos140's Avatar
Car: 91
Engine: 427 with dual stage fogger
Transmission: TH400 with 2.75 1st
Axle/Gears: 4.11 moser 35 splines
Well
I gotta a 383 for sale. No miles since rebuild. Has True roller timing chain, Comp Cams 292 H, Scat crank with H beam rods, Keith Black 10.9:1 pistons with a 64 cc head. The blocks has magnafluxed, cleaned, decked and notched. It had new bearings and main caps installed. The crank has been polished and everything is balanced. The engine has Dart 215 cc heads aluminum, with comp hardened pushrods, Crane energizer roller rockers, Dart single plane aluminum intake and Demon 830 cfm Carb in box and with instructional DVD.
3500 (damn good deal)
If you inetested in the engine I have true dual exhaust that I would be willing to sell.
A torque converter that is matched for the Cam. TCI street fighter.
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
