Parts Wanted 2006 Looking for something in particular? Ask here.
speedo conversion box
Old Nov 3, 2005 | 12:53 PM
j88l98irocz's Avatar
Car: 88 IROC-Z twin turbo
Engine: forged 383 8-1 compression
Transmission: t56
Axle/Gears: 9in 3.50's trac loc moser axles
i need a box that converts the electric signal to mechanical speedo for a 95 t56
Old Nov 3, 2005 | 04:13 PM
jgetti's Avatar
Re: speedo conversion box
I'm curious why you would want to convert an electrical signal coming from the tranny's sending unit to a mechanical speedo. I don't believe that can be done. If the issue is you have a mechanical speedo, then the best thing to do is convert to an electrical speedo. I can help you out with that.
You may also be able to remove your electrical sending unit from the tranny and put in a cable unit.
If this is not what you're attempting to do, please clarify....
Old Nov 4, 2005 | 08:47 AM
Transmission: t56
will i need a new speedo cluster then ?
Old Nov 4, 2005 | 08:49 AM
Transmission: t56
I just want the speedo 2 work, the car keeps throwing a code for vss.
Old Nov 4, 2005 | 09:51 AM
CamaroKid89RS's Avatar
Car: 89 Camaro RS/SS
Axle/Gears: 10 bolt with 3.42
A company makes a device that does exactly what you want. I know because I am looking at the same thing. It's called Cable-X.
Just google it and you'll find it. It takes the vss signal and converts it so that your mechanical speedometer can work. I think it can be reprogrammed for different wheel sizes and gear ratios also.
Old Nov 4, 2005 | 12:17 PM
transamshh's Avatar
Car: 85 Trans Am
Checkout this site
http://www.hawksthirdgenparts.com/inc/sdetail/17491
GTAman
Jul 3, 2024 07:29 PM
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
TrevinE
Sep 14, 2015 03:20 PM
