V6 T-5 Swap parts
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
I have a complete V6 5 speed assembly from a 92 3.1 car. It will work with the 3.4. I am located in KY and could ship it if necessary. LMK............jt
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
How much do you need? Do you need everything 5 speed related?
Trans
shifter
Bellhousing
Clutch& Pressure Plate
Flywheel
clutch fork
throw out bearing
Clutch Hydraulics(Slave cylinder/master cylinder)
U bolt for mounting master cylinder
Pedal Assembly
Rubber Boot in Trans tunnel
And all pertaining nuts and bolts
If so hows $500 shipped for everything, if there are parts you dont need we can negotiate a lower price. If you prefer to call me my cell is (859)338-7351..........jt
Trans
shifter
Bellhousing
Flywheel
clutch fork
throw out bearing
Pedal Assembly
Car: 86 IROC-Z
Engine: LB9
Axle/Gears: limited slip disc
Re: V6 T-5 Swap parts
Originally posted by Nocturnall
I need a T-5 swap for a 3.4l v6. Please anyone.
Will
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Re: Re: V6 T-5 Swap parts
Originally posted by priest1981
You may want to post in the parts for sale forum.
Will
Will
Car: 86 IROC-Z
Engine: LB9
It's posted in the right forum since I"m looking to buy and I started the tread.
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
