Parts Wanted 2006 Looking for something in particular? Ask here.
Flexplate
Old Jan 5, 2006 | 02:51 PM
Shake Zula's Avatar
Car: 1986 Olds Cutlass Supreme
Transmission: 200-4R
Axle/Gears: good question...
Flexplate
Need a 168 tooth flywheel with dual bolt pattern for 86-later 1 piece rear main seal.
Old Jan 6, 2006 | 12:18 AM
bb6802's Avatar
40.00
Old Jan 6, 2006 | 03:57 AM
Pat Hall's Avatar
Hmmm, if you need a stock one, I think they're only 153 tooth. If it's the stock one you need, I have an extra one I'll sell for $20 plus shipping. Pat.
Old Jan 6, 2006 | 03:14 PM
Shake Zula's Avatar
I thought they came in 168 and 153. TCI Streetfighter converter says to use a 168 tooth only.
Old Jan 7, 2006 | 01:32 AM
Pat Hall's Avatar
Hmmm, that's kind of a gray area for me as well. It seems like I remember some of the guys on here saying the T5 thirdgens use a different starter, which would probably be the one for a 168 tooth flywheel. I know most of the older TH350 168 tooth flexplates had dual bolt patterns to accomodate different spacing on the converter lugs. If your TCI converter uses the larger lug bolt circle, I guess you'd have to run a 168 tooth flexplate since the 153 tooth ones only have one bolt pattern on them, which is for the smaller bolt circle. I'd be willing to bet one of the aftermarket manufacturers makes a larger flexplate for 87 and up one piece rear main engines. Hopefully, either TCI can tell you what you need to do, or maybe someone here on the boards knows the solution?
Old Jan 7, 2006 | 06:43 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i have never seen a gm plate that didnt have both patterns, regardless of diameter/tooth count
you could run a 153 tooth plate and straight across bolt pattern starter jut fine
i think TCI just wants to sell you more unneedingly
im from the boat that runs whatever works,
not what a company thinks that i need to buy and use
i dont really see what the big deal is
if anything just invest in a tape measure, when in doubt
good luck
Old Jan 7, 2006 | 08:08 AM
Pat Hall's Avatar
Oh trust me Fast68, I'm from the same "boat" as you! I don't believe in buying unnecessary, expensive parts either. But I can tell you the flexplate for the one piece rear main engines definitely has only one bolt pattern in it (i.e. only three holes, not six). The thing is, I can't imagine that this TCI converter wouldn't have the proper bolt spacing for the stock flexplate that 700r4's use.
Old Jan 7, 2006 | 08:20 AM
Shake Zula's Avatar
Im gonna start a new post and see what others say.
84LsxZ28
May 17, 2020 02:21 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Stangski09
Nov 14, 2015 01:27 PM
roysatikas
Sep 22, 2015 08:15 PM
roysatikas
Sep 7, 2015 08:08 PM
