LB-9 L-69 camshaft
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
LB-9 L-69 camshaft
I need a hydraulic flat tappet cam and lifter set. but the specs need to be what a 5.0 tpi motors is or the 5.0 h.o carbed motor. for emmisions reasons.
I'm not interested in used stuff
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You can get a good cam and lifter set from Summit or Jegs for ~$100 that will pass smog all year long and give you more power. Dont limit yourself to stock stuff.
what were the original cam specs for these cams
From the tech data on this board:
https://www.thirdgen.org/tech-data
I'm guessing the L69 cam is
305 AT 14088843 .403 .415 202 206 114.5 (115/-114)
And the LG4 cam is
305 AT 14094097 .350 .385 178 194 109.0 (106/-112)
And the LG4 cam is
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
FYI, I'm using a Crane Compucam pn 114122. Its a very mild cam but a step above stock in my 84 z28 L69 and has no problems passing emisions here in NY. Of course CA is a land of its own rules and regs ! I also have a very low miles used L69 factory cam if you need it. With new lifters it will work just fine.
88SS6SPEED
Nov 11, 2015 07:05 AM
GTAman
Sep 26, 2015 02:01 PM
