Parts Wanted 2006 Looking for something in particular? Ask here.
Vortech V-1 Supercharger Mounting Kit
Old Apr 28, 2006 | 01:18 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
A buddy has a Vortech V-1 Supercharger and needs the mounting kit. It consists of the following:
The kit includes the following.
4GF111-021 MOUNTING BRACKET ASSEMBLY 1
4GF011-021 Mounting bracket 1
4GF111-021 Mounting plate 1
4GF017-041 .875 x 4.305 spacer C 1
4GF017-051 .875 x 2.305 spacer D 1
4GF017-011 Idler spacer 1
7A375-525 3/8-16 x 5- 1/4” bolts 2
7A375-300 3/8-16 x 3” bolt 1
7A375-100 3/8-16 x 1” bolts 7
7C010-030 M10-1.5 x 30mm bolt 1
7K375-040 3/8” AN960 flat washers 10
7J375-044 3/8” SAE washers 5
7L375-075 3/8” lock washer 1
7A375-550 3/8-16 x 5-1/2” bolts 2
7A375-17A 3/8-16 X 1-3/4” flat allen bolt 1
4GF016-160 Idler ribbed pulley 1
7C012-050 12mm x 1.75 x 50mm bolt 1
7G010-175 12mm x 1.75 nut 1
4GF116-010 CRANK PULLEY ASSEMBLY 1
4GF016-011 Crank pulley 1
4GB017-041 Crank pulley spacer 1
7B437-400 7/16-20 x 4” bolt 1
7J375-044 3/8” SAE washers 3
7L375-075 3/8” lock washers 3
2A046-988 Belt 1
2A046-605 Belt 1
7B375-275 3/8-24 x 2-3/4” bolts 3
4FA111-032 BELT TENSIONER ASSEMBLY 1
7J012-092 12mm flat washers 3
4FA011-032 Belt tensioner 1
4FA016-150 Smooth pulley tensioner 1
2A017-010 Idler pulley spacer 1
7C012-020 12mm x 1.75 x 20mm bolts 2
7C012-022 12mm x 1.75 x 22mm thin head bolt 1
Can you help him?
Old May 2, 2006 | 02:50 PM
wesilva's Avatar
Transmission: 200R4
Ok....how about the complete supercharger set-up? Does anyone have the complete kit? NO JUNK!! Paxton, Procharger or Vortech
Terrell351
Jun 13, 2021 01:13 PM
deracer
Apr 11, 2016 12:04 AM
toronto formula
Nov 10, 2015 06:17 AM
anesthes
Aug 24, 2015 08:32 AM
PestilenceIV
Aug 20, 2015 03:32 PM
