1988 supercharged 383 pics
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: 1988 supercharged 383 pics
Nice, i think one day i might go with a centrifical if i dont gop with a single turbo.
Looks killer.
Looks killer.
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
that is some major -cc on top of those pistons. trying to have it run on pumped gas are we?
Car: 88 Camaro
Engine: Supercharged 383 stroker
Axle/Gears: Auburn posi motive 4:10 Moser axles
It will be 8.5 to 1 compression so pump gas i will also have methanol injected
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Cool, how much you expecting to make with that combo? I wanted to go roots on this last build with another set of heads, but all of the single carbed blowers that i looked at would only support ~550 at the crank from what i was told with out overdriving the hell out of them.
Car: 88 Camaro
I am not looking for alot of horsepower we are hoping for about 500 at thr rear wheels or around that i just always wanted a supercharger i am not much on the dual carb not really sure what it will do but i do want to take it to the dyno
Car: 88 Camaro
They are from erwparts.com there part number for them is 148750 and they are srp 31cc reverse dome forged
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
Looking good. Which heads are those?
Car: 88 Camaro
I bought them off ebay for like 85 shipped they look really good i think something differant
Car: 88 Camaro
Well its been a while but after getting after my mechanic it should be done by the end of june will post pics asap after finished
Car: 88 Camaro
Finally got the motor in the car will post pics in the next day or two
Car: 83Z28 HO
Transmission: G Force 5 speed
That looks sweet! What size blower is that? How much boost do you anticipate you'll get from it with the pulley you have?
Oddly enough, I should be dropping my blown engine in the bay in a little over a week. Gotta say I'm jealous you can run a big cap HEI distributor with that setup, because I couldn't with mine which forced me to buy a whole new one....
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Supercharged, lightly sand down the areas on the block where rust is starting to become prevalent (fuel pump, waterpump, etc.), and once your finished, lightly coat the area with some olive oil. This will prevent rust from developing in those areas again until your ready to install everything, and just before you install the parts, spray the area with some carb cleaner first to remove the olive oil from the block. You mentioned that the engine is already in the bay, so if the parts were already installed, then take the advice for any furture builds....
Car: 88 Camaro
Here are the pics in the bay tranny is connected also just not bolted tight.that is whay the motor is tilted so much.Should be driving by end of the june.The blower is a 144 running around 6 or 7 psi stock hopefully
Demon 825 carb
Demon 825 carb
Car: 88 Camaro
Also just a heads up this will most likly be for sell when finished
Car: 88 Camaro
Little update the drivetrain is all good to go,subframe connecters are in all exhaust work should be done by end of this week.Saturday planning on wireing it up and hopefully starting it.I will post pics this saturday of the progress
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
I believe the valve covers are Pro-Comp. I have the same ones i got off a racingjunk.com seller, i think i paid the same as you did
Car: 88 Camaro
The car should be running by this weekend and the date to pick up is friday the 27th.He is going to turn down the rev limiter to 4500rpm for the weekend then after i give it back the following weekend he will fine tune and set it for 6000 rpm where it will stay.Will keep everyone updated.Its getting close finnaly after 6 months
Car: 91 Z/28
Engine: 6.3 L98
Transmission: TH350 4500 STALL
Axle/Gears: 3.73s
Looks good, what size hood you running?. I have a 3 inch cowl. Wonder how close it would be? Good luck!
Car: 88 Camaro
It is a 4 inch ther is about a half inch between the top of airfilter and hood.Should be running this weekend hopefully
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
Hell yeah--that motor is some real eye candy!
Can't wait to see a vid of the car running. Keep us updated!
Car: 88 Camaro
The Good:Drove the car today and have to say wow Tire frying sob plenty of power and only on 4 psi.Rolling 25 mph floor it and leave posi up the road still need more boost and more timing
The Bad:
3rd and overdrive do not work.Bought the trany off ebay new rebuilt my a$$ Guy is also no longer a registerd user so it all me.Will be another couple weeks till done
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Wow that sucks about your trany. So how much power do you think you will have when its all finished?
kevin
kevin
Car: 88 Camaro
Car: 88 Camaro
Talked to my brother tonight he got it out and apart.It was never rebuilt the 3rd and overdrive clutches was black and the case needs replaced some of the pins are wore bad enough where they are almost threw the case.I will keep you updated.
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
ditch the overdrive tranny junk and get a TH350, they are cheap, plentiful and strong. Doesn't sound like your worried about gas mileage anyway. check craigslist.com they range 100-200 used.
Car: 88 Camaro
No i want the overdrive for traveling to car shows on interstate 81 and visiting friends and family
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Car: 88 Camaro
Got a case for 40 bucks will be ordering the rest of the rebuild parts monday morning.
Also something to think about this will be up for sale or partial trade when finisihed.It cost way more than planned and took alot of extra money i hate to do it but i have no choice.Will keep you posted and will make a new thead of coarse for thr sell or partial trade
Car: 88 Camaro
Well a little update i got the car today.The only thing in the tranny is still bad,it needs a new one i brought it home to decide wht i want to do.I drove it home in first and second its only 5 miles and speed limit is 35 to 45 so no big deal.car has lots of power runs great.going to clean and wax it and a couple other things before i decide.I am going to do one of three things
1.clean it up sell as is
2.get new tranny sell it
3.get new tranny and keep it
Not really sure yet a blast to drive but i have alot of money in it and not sure if i want to put more in it.
Car: '89 IROC-Z
Engine: 355
find a th350 for 200 bucks throw it in and drive it for a while
Car: 88 Camaro
I am going to keep it and fix some things.First i have to rejet carb get a better water pump an radiator.I have it all apart right now waiting on parts it is in my garage now i am doing mostly myself with some coaching from my brother.Will get some pics soon.
Car: 88 Camaro
I only drove it about 5 miles home and thats it i will get a video when it is all fixed up
Car: 88 Camaro
Got new water pump radiator rejeted carb and a couple other little things done.Will post ne pics and i will try to post video i never did that before
Car: 88 Camaro
