Yay nitrous! Booo lean...
Old Mar 4, 2010 | 10:01 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
OK, this is mostly a ploy to get people to look at this , but I also wanted to show everyone a datalog of what happens to a maf car when the jet is plumbed behind the maf. I hit the button about 54 secs in. You can see how reported airflow drops as the nitrous comes in. This was a dry kit made for a 5.0 mustang that boosts fuel pressure to 80psi to add the extra fuel... sortof. Apparently it takes a little while to build up pressure as you can see it lean out and gradually richen back up. Probably would've had better results on an SD car. No meltdown but one plug got DAMN hot. Needless to say I'm running cooler plugs now and moving the jet.
File Type: zip
Last edited by bl85c; Mar 7, 2010 at 10:37 PM. Reason: Err, I mean 54 secs in. Not 34.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
RedLeader289
Sep 23, 2015 06:50 AM
anesthes
Sep 18, 2015 12:34 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
KlayBuRn
Aug 4, 2001 12:54 AM
