400 on the sauce in the makin
Old Apr 24, 2002 | 10:00 PM
12sec305's Avatar
Just got my 400 couple days ago starting to build. Gonna go basic rebuild with JE forged pistons and a whole lotta of juice.shootin for low 11's.Everyone said the little 305 wouldn't go no where but it pulled through and is in the twelves. not a timeslip for it yet but parkway pulls with friends prove it.Any input would be cool.....
Old Apr 25, 2002 | 09:24 AM
JC93Z's Avatar
Just for your info parking lot adventures doesn't mean you have a 12 second car. And until you get timeslips I wouldn't say you have one. There were alot of times when I thought my car would do something but then when I went to the track I was dissappointed. Not trying to start a flame war just saying, don't say something without proof.
Old Apr 25, 2002 | 09:32 AM
Skweezn87's Avatar
Car: 78 Vette Pace Car (730 ECM MOD)
Engine: 427 SBC
JC93Z -
Exactly.......
Old Apr 25, 2002 | 09:45 AM
Biochem's Avatar
Car: 2002 SOM z28
Maybe this means my Carolla is just as fast as a Viper... we both were doing 65mph on I-40 the other day!
Old Apr 25, 2002 | 10:09 AM
Bill87GN's Avatar
Jesus, I must have a f*ckin rocket ship then. I was driving down the street the other day and looked up and saw a plane. Could have sworn we were both going the same speed because I was pacing him even though he was a mile above the earths surface.
Until you get a timeslip, your estimations mean **** :lala:
Old Apr 25, 2002 | 10:15 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Oh yeah, well i raced a guy in a new eclipse the other day and i must have been accelerating twice as fast as him cuz i blew the ***** off his radio. They run what, like 16s, so i must be in the 8s WOW!
Old Apr 25, 2002 | 10:43 AM
Jester's Avatar
Bah thats nothing. The other day I raced this new Z28 on FOOT! I had him for the first 10 or 15 feet too....that must mean I can run high 12's easy!!!!!!
Old Apr 25, 2002 | 10:47 AM
JC93Z's Avatar
LOL @ Jester!!!
Old Apr 25, 2002 | 10:58 AM
Guido's Avatar
Car: 2000 Trans Am
What kind of input are you looking for? If it were me, I would find a 2 bolt 400 block, have it splayed to 4 bolt mains with aftermarket caps and use a good crank. Around 650 ft # of torque you start pushing the block past its limit. not to mention that 400's are notorious for having thin cylinder walls and decks. you will want to ave the block checked very good by a shop who has the means to do it. You may also consider plugging the large holes in the deck to add some more strength and then have it decked off.
<---------- Has had a factory 400 block and learned all the short falls.
Old Apr 25, 2002 | 08:26 PM
strokeronthesause's Avatar
dont listen to...........
these people !!!!!!!!!!! they are all slow!!!!!! and if you think your fast ill make that 400 run circles around all of you!!!!!! anyway 12sec305 you know what you have to do dont ask knuckle heads who want nothing else but to put u down.
Old Apr 25, 2002 | 11:07 PM
Guido's Avatar
Car: 2000 Trans Am
Re: dont listen to...........
Gee thanks strokin it ... period.
I gave an honest and helpful answer. Ive BEEN DOWN THE 400 BLOCK ROUTE AND I DO KNOW WHAT IS WEAK ABOUT THEM.
Old Apr 26, 2002 | 07:20 AM
JC93Z's Avatar
So what is you best if we are all so slow stroker????
Old Apr 26, 2002 | 08:15 AM
Biochem's Avatar
Car: 2002 SOM z28
Re: Re: dont listen to...........
Honda Civic speed... Type R! :hail:
Old Apr 26, 2002 | 08:24 AM
Bluebird's Avatar
Car: 1991 Pontiac Firebird
Transmission: 700R
Are you serious?
Wow... Are you serious?
:sillylol:
Old Apr 26, 2002 | 09:29 AM
Skweezn87's Avatar
Engine: 427 SBC
strokeronthesause
Man .. you hit the nail on the HEAD! We are slow...... we are just ALOT of wanna bee fast mo fo's....
Rick
Old Apr 26, 2002 | 09:30 AM
Jester's Avatar
Re: Are you serious?
:sillylol:
lol kindasorta. I didn't do it myself just the other day, but I have seen it done. Try it sometime. Any decently quick person will win in say..the first 10 yards...everytime.
Old Apr 26, 2002 | 01:30 PM
rhuarc30's Avatar
Geez guys the guy just asked for some input, maybe he's wrong about the times, but we all know how inaccurate the butt dyno, give him a break and some good advice and he'll know better next time.
If you do a good build on the engine 11's on the engine is no problem with a 400. Guido's reccomendations were good, the splayed caps are a lot stronger, a few hundred extra dollars though, but worth it. I'd reccomend the nodular iron ones instead of the steel, they match the expansion rates of the engine block better. Use the forged pistons and a good set of forged rods (I like eagles, but other companies make quality rods as well). A forged crank at the level your talking about is not really necessary, but I'd upgrade at least to an aftermarket nodular iron one. You're gonna have a bunch of bottom end torque so use a bigger cam to balance it out and you can really make it rock. Do the hydraulic roller retrofit on the block for easy maintenance and more power, if maintnecane isn't as much of an issue go with a small solid roller and be prepared to run the valves occasionally. I like the AFR 210 heads for the 406, but they are a little pricey, but a good set of heads is a must, that 400 will be an air hungry b*****rd, so make sure you do the upgrades to feed it.
Old Apr 26, 2002 | 07:13 PM
12sec305's Avatar
what do u think about the vortech heads
What about the vortech heads do u think they are too small for the motor i was gonna get a full race port on them im like maxed out is it worth it or maybe outa the box afr's for now till i can have them ported, and maybe a solid flat tappet to take some weight off the valve train i was also thinkin about the pro lightning heads made by pro topline 228cc 64 cc 307cfm 210cfm at 700"lift might be a better by than the vortech and anybody have results of the blower on a carb setup by vortech like how much pounds of boost and is it efficient thanks
Old Apr 26, 2002 | 10:24 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
Don't use the Vortecs on that motor. They will be to small. Even if you "max port" them, they still won't respond well. I would start with something 200cc or bigger.
Old Apr 27, 2002 | 06:52 AM
Biochem's Avatar
Car: 2002 SOM z28
Re: what do u think about the vortech heads
Originally posted by 12sec305
What about the vortech heads do u think they are too small for the motor i was gonna get a full race port on them im like maxed out is it worth it or maybe outa the box afr's for now till i can have them ported...
Pro Action... Vortech heads are too small
Hotrodboba400
Dec 10, 2019 07:07 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
