Help Me Pick A SuperCharger
Old May 5, 2002 | 03:23 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
OK, this won't be for a couple years when college is done, but I just wanted to get an idea of what I would be looking for and how much. I was thinking of a centrifugal s/c. Not sure which to get, price, or how much boost to run.
It will be going on the motor in my signature, plus I'll have a Comp Cam, ported heads, Edelbrock RPM intake, 2500ish stall TC. If that helps any. So basically the bottom end will remain stock if I can, which means for the time being I won't be able to run too much boost I guess.
Any idea how much power I would be looking at being added?
Thanks for any input.
Old May 5, 2002 | 03:50 PM
DABE's Avatar
Mark,
Im looking into ATI or Vortechs system...
ATI looks like this.... http://cgi.ebay.com/ebaymotors/ws/eB...tem=1825719535
And the Vortech looks like this attachment...Summit carries the Vortech system for ~2300 bucks
Heres what comes in the vortech kits..
-Vortech gear driven V-1, S-Trim supercharger
-Technologically advanced impeller and housing design developed in Vortech's supercharger test cell to meet SAE std. J1723
-Cast aluminum mounting bracket with all necessary hardware
-6061-T6 billet aluminum twin mounting plates for rigid supercharger attachment
-Automatic belt tensioner with dual bearing tensioner pulley
-3.5" diameter cast aluminum discharge tube assembly with clamps, heat resistant silicon sleeves and quality stainless steel clamps
-10-rib, 6061-T6 billet aluminum supercharger crank pulley with hard anodize finish (6" diameter)
-Unique oil feed and oil drain assemblies deliver the best possible lubrication and cooling for the supercharger unit
-Cast aluminum carburetor enclosure assembly (use with 4150 Holley or Demon Carburetor)
-Enclosure features front and rear -8 fuel inlet ports as well as multiple locations for pressure/vacuum connections. Linkage arms, splined shaft, and left/right hand spherical rod ends are included for simple throttle connection and adjustment
-Optional fuel line kits are available. They include custom bent stainless steel lines, billet -8 bulkhead adapter with fuel pressure port and plug, -8/-6 junction tee, aluminum swivel hose ends and USCG approved fuel hose
Hope this helps...
DABE
RedLeader289
May 28, 2019 01:47 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
FormulaEngland
Sep 30, 2015 01:50 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Gordonr1973
Sep 29, 2015 11:59 AM
