Question on making 305 turbo
Old May 5, 2002 | 10:00 PM
Tbird's Avatar
I talked to a guy today that can make custom headers so i can do twin turbo on my 305 the question is is there enough room and does anyone know what to lower the compression to? I planned to run about 20 psi and info would be greatly apprecaited thanks...
Old May 6, 2002 | 10:24 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
TT has been done. Look at www.skulte.com, he has a nice setup. 20 PSI is quite a lot... that isn't somthing you can just throw on a stock motor. Most people here with a power adder are running 8-12 PSI. Search the board a little and pick up a book called "Maximum Boost" it is VERY informative.
I assume that you will want to run junkyard turbo's. Have you decided what car you are going to get them from? Turbo specs are a very important part of the build up.
Old May 6, 2002 | 03:10 PM
vortech305's Avatar
There is room, If ur building a TPI it can work, but if its a TBI dont waste ur time. 20PSI is way too much especially for a 305. Go with a 8.5.1 compression and 4 or 5 lbs of boost on each turbo, Ur also gonna need custom intercoolers. Yes they will fit your third gen. its all about the benjamins:lala:
Old May 6, 2002 | 07:11 PM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
Uhm....Thats 4 or 5 lbs of boost.
Old May 6, 2002 | 08:38 PM
daverr's Avatar
:nono: why would u go to the trouble of dropping compression of the 305(or anyother engine).i say u leave the 305 alone at 9.5-1(stock compression). install forged pistons if your really serious and plan on running the 20 psi.by the way at 20 psi and that compression, race gas is pretty mandatory.
have fun
dave
Old May 6, 2002 | 09:43 PM
vortech305's Avatar
Originally posted by daverr
:.by the way at 20 psi and that compression, race gas is pretty mandatory.
dave
If u say so but when his motor blows up im sure he'll be looking for u:lala:
Old May 7, 2002 | 04:53 PM
Guido's Avatar
Car: 2000 Trans Am
jhawkeye
May 25, 2022 06:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
st.evel07
Aug 13, 2015 06:15 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
