ATI's Twin Hi-Flow Intercooler System on a Third Gen? Stay Tuned...
Old Jan 23, 2003 | 06:18 PM
  #101
mypontiac's Avatar
Car: 1991 Conv. TA
Engine: Forged 350 with D-1SC
Worked for me just now, but anyway try:
http://mywebpages.comcast.net/bherter/index.html
www.pcmforless.com forwards you to this link.
Old Jan 23, 2003 | 10:57 PM
  #102
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
Link worked fine for me also. This is some awesome info. thanks man.
Brian
Old Jan 23, 2003 | 11:06 PM
  #103
mypontiac's Avatar
Car: 1991 Conv. TA
No Problem.
Tell Alvin I said Hi!!!
He promisses to get the prom just right to your satisfaction. Don't see that much anymore.
I am going to collect data this weekend using a trial run of TTS software. I will then send it to Alvin for him to upgrade the program. He will then forward the program to me to burn into my chip using Pocket Programmer.
Damn technology is great!!!! :rockon: :rockon: :rockon:
Old Jan 24, 2003 | 09:13 PM
  #104
mypontiac's Avatar
Car: 1991 Conv. TA
I went all out with the TA today and recorded data using TTS software.
First time going all out WOT actually!
Unbelievable power. Willie once told me to bring a change of underwear when I first tried the boost!!! Ha!
I sent the data to my Prom programmer who will make adjustments as necessary.
Hey Willie, you still followin this post. Have not heard from you in months.
Oh well. I'll have to have all the fun here without you!!!! :lala: :lala: :lala:
Old Feb 21, 2003 | 10:52 AM
  #105
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
I'm interested in how this is progressing. I have a question though. Will this install work on a stock setting camaro? My battery is on the passenger side, and the cannister is the the middle on the drivers side. Will I need to relocate anything before I can get the twin intercoolers to work?
Old Feb 21, 2003 | 11:03 AM
  #106
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
not dead link anymore
Old Feb 21, 2003 | 03:02 PM
  #107
mypontiac's Avatar
Car: 1991 Conv. TA
Iroc Z,
The kit comes with a bracket to relocate the battery.
Not sure about the vacuum canistor. Mine was already relocated.
These items are actually minor compared to the rest of the install.
Old Feb 24, 2003 | 05:41 PM
  #108
Originally posted by mypontiac
Iroc Z,
Pretty much a PITA huh? Well, I still like procharger a lot better than most companies out there.
If you were to start on a stock car, hypothetical, how long would the total install take in hours? Just a wild guess will do, I want to plan the time off work that I will need to install everything and get it running. Plus a little extra to rest on
Old Feb 24, 2003 | 07:36 PM
  #109
mypontiac's Avatar
Car: 1991 Conv. TA
Lets see..........
I started the install about 4 months ago and am in the tuning stage now.
I took off 2 weeks during Christmas and got the bulk of it done at that time.
I had done a few other little weekend things prior to that.
It is a fun project, but don't be affraid to work hard and be creative!
Old Feb 27, 2003 | 06:04 PM
  #110
I need to get another car before I get into that. This is my only car for right now. Thanks!!
Old Feb 27, 2003 | 07:30 PM
  #111
mypontiac's Avatar
Car: 1991 Conv. TA
Yea, that would help.
I have another to drive when the supercharged car is down.
My adjustable fuel pressure regulator just died so it will be down for a few days for that repair.
Always something with older modified TA's!!!
Good luck.
Old Mar 14, 2003 | 04:01 PM
  #112
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
What size intercoolers does the "kit" use? I would like to do something similar with my car.
I am also debating putting on a 91-92 nose and putting them behind where the turn signal/fog lights go.
Old Mar 26, 2003 | 08:09 PM
  #113
87camarodan's Avatar
carburetors
what would i have to modify in this kit to attach that to a carbureted 87 sport coupe?
I really like the idea of turbocharging but I dont wanna get away from my carburetor
Old May 26, 2003 | 12:17 AM
  #114
92 heritage z28's Avatar
some questions for you all?
1-why use rubber hose? would not pvc, stainless tubing, or somethinf else work better?
2-does installing colers so close to the front end cause any clearance problems? we all remember how the lower spoliers rub on our z and ta's?
3- looked for ******* post on tenicious web site and could not find it?
and just a comment..
checked ******* info, and more pics on z web site, and i am totally impressed on his pics, attention to detail, and plan of attack . so ******* here to you dude!:hail: :hail: :hail: :hail:
Old May 26, 2003 | 10:06 AM
  #115
mypontiac's Avatar
Car: 1991 Conv. TA
Why not use rubber???? I wouldn't want to try fitting something rigid through the entire system.
I wouldn't go looking for driving it off road, but if it can clear the front bumper, it will clear the intercoolers. You can see in photos above.
http://www.tenperf.com
Old Jul 7, 2003 | 02:44 PM
  #116
bluegoose's Avatar
Car: Firebird
Engine: 383
Transmission: 700R4, lots of Mods
Hi all, I have a '89 bird with a P1SC two core IC. I need more air flow to cool the motor, on hot days my temp goes to 220. Anyway I was wondering if this 2 piece IC will work on a 1989 bird. My IC blocks alot of air flow going to the radiator. Any information will be greatly appreciated.
Brad
Old Jul 7, 2003 | 09:57 PM
  #117
mypontiac's Avatar
Car: 1991 Conv. TA
Yes.
Contact Dave at http://www.tenperf.com
Old Sep 5, 2003 | 06:10 PM
  #118
D M N's Avatar
Car: Right now 93 Lumina
Engine: 3.4 DOHC
Transmission: 4T60-E
thats a awsome setup
Old Sep 5, 2003 | 06:49 PM
  #119
Mark A 91Formula's Avatar
Car: 91 Formula
Axle/Gears: 10 Bolt 3.23
pvc works but it is a temporary solution at best. The standard hardware store stuff is schedule 40, thick stuff, it does make for some clearance issues. Also it is not stable enough for underhood temps long term. The pipe I used is starting to deform in places. One piece on the blower intake side had to be replaced with a 90deg rubber hose, it works but I lose about 4lbs boost over the old setup untill I get a proper piece made up.
Old Sep 19, 2003 | 10:28 PM
  #120
mypontiac's Avatar
Car: 1991 Conv. TA
Just an update to this post.
I have added an alky injection system to help eliminate any predetonation.
Willie swares by this in the Arizona heat and my climate is not much better in Louisiana.
Once the kit is tuned I will be upgrading to the 15 # pulley.
Here is a photo of the alky controler.
Will update with some dyno numbers once I get the new pulley installed.
Attached Thumbnails ATI's Twin Hi-Flow Intercooler System on a Third Gen?  Stay Tuned...-smc2.jpg
Old Oct 18, 2003 | 08:22 AM
  #121
Soulrev's Avatar
Car: Formerly - 87 T/A, 87 Bird.
Phuckin' Uber! :rockon:
Old Feb 29, 2004 | 09:20 PM
  #122
meffie's Avatar
Engine: 383ci w/ Blower
Has anyone tested this on a straight discharge vortech yet?
Old Apr 13, 2004 | 01:49 PM
  #123
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
That is the craziest intercooler setup ive ever seen. Its cool
Old Aug 20, 2004 | 02:57 PM
  #124
Ucantcme57's Avatar
Where has this gone now? It's been awhile.. Been following it and wondered how it was going...?
Old Aug 20, 2004 | 11:15 PM
  #125
mypontiac's Avatar
Car: 1991 Conv. TA
Its been going just fine with my original set up.
I tried running the 15# pulley, but had problems with cold start up.
I had terrible popping through the intake and blower.
I went back to the original pulley and all is fine.
The car is still very fast and fun to drive.
I recommend this set up for anyone interested in a supercharger.
Old Aug 24, 2004 | 02:10 PM
  #126
FireRed91Z28's Avatar
Car: 91 Z28
Engine: currently 350...BUILT 383 soon
Transmission: T56 w/4.10's
im looking to do a similar set up for a twin turbo system and was wondering how much air do those intercoolers flow each? how much power can they support? im looking for 800 RWHP which would equate to around 1000 FWHP.
Old Aug 25, 2004 | 08:40 AM
  #127
KS91Z28's Avatar
They're only rated for 750 hp.
Old Sep 12, 2004 | 11:11 AM
  #128
Toneyb35's Avatar
Car: 91' Z28 Vert
Engine: 305TPI
Transmission: 5 speed
I recommend this set up for anyone interested in a supercharger. [/B]
Hey Sean I just sent you and email. I'm interested in seeing your setup personally, if you don't mind. I know my car is a Z28 but seeing is believing. I understand my setup would be more like Willie's. But I'd like to see exactly what I'd be getting into as far labor goes. I have another mode of transportation so My Z28 could sit up for a while to complete the install in a timely matter. I take off work for the winter so I'll have time to do plenty of MODs. I've ordered numerous parts from Spohn, Lon (TDS) and a few little hard to find stuff off eBay, so I plan to totally finish my car by spring. Your install looks awesome. Great Job!!!
Toney
Old Sep 24, 2004 | 06:36 AM
  #129
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
Mypontiac,
I got may answer in another post. Thanks
Old Nov 22, 2004 | 08:28 PM
  #130
No5.0's Avatar
Car: Buick
Engine: 231
Transmission: 200r4
Mypontiac what do you have the smc kit pump speed set at , and is it the progressive kit?
Popping through the intake usually indicates a lean condition.It's crazy for me to see you running only 23# injectors. What is your vacuum line off at idle fuel pressure? It is boost referenced AFPR right. I'll bet the injectors have a duty cycle of 95% if not more.
Old Nov 22, 2004 | 08:59 PM
  #131
mypontiac's Avatar
Car: 1991 Conv. TA
It is the progressive kit.
I have it set about 4/5 to max position.
Stock FPR. The AFPR kept blowing??? So I went back to stock.
Yes, I figured that it was a lean condition due to the added air flow even at idle with the bypass active.
There is still a noticable difference in idle with the blower active vs. not active.
I have not persued determining the duty cycle of the injectors. I used the flow rate recommended by Willie. I have a air/fuel ratio gauge and monitored it during the programming of my custom chip.
Everything is fine with the pulley that was developed with this chip.
As you know, I tried using a smaller pulley and things were not happy.
I have made myself stay content and the car runs perfect.
Hope this helps.
MyPontiac
Old Nov 23, 2004 | 07:39 AM
  #132
No5.0's Avatar
Car: Buick
Engine: 231
Transmission: 200r4
A good apfr sounds like what you need to lean it out on the bottom end and give you a smooth idle.
One thing that sucks about 3rd gens is tuning it is so expensive for someone else to do it.
Old Nov 26, 2004 | 06:33 PM
  #133
primo's Avatar
Did you run it at the track, this is real test of how thins are working. That will be my next Mod.
Very nice.
Old Nov 26, 2004 | 07:27 PM
  #134
mypontiac's Avatar
Car: 1991 Conv. TA
Have not made it to the track, although I am anxious to do so. Since I have a convertible, once I run I expect to be told that I need a roll cage.
I have went through much effort to get the stock regulator put back in place after blowing at least 3 AFPR. The diaphrams would fail with the ATI fuel system that increases pressure during boost.
I am just enjoying the car as is for now.
Old Nov 27, 2004 | 05:31 PM
  #135
No5.0's Avatar
Car: Buick
Engine: 231
Transmission: 200r4
The buick (gn) afpr uses a boost reference where as the fuel pressure starts at lets say 45 and increases as 1 psi of boost is introduced 1 psi of fuel pressure is increased. So I run 20 psi of boost with a base of 45psi(vac line off)=65 psi at wot at max boost.
All I'm trying to state is that if ati can't make a good afpr, somebody does and trust me it's worth it.
Old Nov 27, 2004 | 06:03 PM
  #136
mypontiac's Avatar
Car: 1991 Conv. TA
Yes. I also have a 89 TTA and the AFPR that are available are much better than what you can get for the 91 TA. I went through 2 Holleys and one other brand. All failed during boost. ATI does not supply the AFPR. Actually, the AFPR is not required under their setup. A seperate fuel management diaphram is used to increase pressure under boost.
Old Nov 28, 2004 | 01:43 PM
  #137
No5.0's Avatar
Car: Buick
Engine: 231
Transmission: 200r4
So ati uses an fmu to increase fuel pressure.
Is your tta stock?
Old Nov 28, 2004 | 09:34 PM
  #138
mypontiac's Avatar
Car: 1991 Conv. TA
Yes, now you see where I am coming from. ATI uses an FMU.
I was considering switching the ECM to the same as the GN and TTA, but was too far into the mods. So yes I have the ATI FMU.
This is what gives such great fuel pressure that is blowing the ADFP during boost. It is a progressive thing. You will notice the FP changing over time as the diaphram fails.
I have a stock TTA with 13,800 miles. I am a member of a news group for about 2 years. I always have the itch to modify the car, but want to preserve the originality.
Am currently considering high output fuel pump with hot wire kit, AFPR, and adjustible waste gate as a first mod.
Old Nov 30, 2004 | 03:30 PM
  #139
No5.0's Avatar
Car: Buick
Engine: 231
Transmission: 200r4
If you do decide to modify your turbo car (I wouldn't) look into the MAF translator and ls1 style MAF instead of using the AFPR. The translator allows you to tune the car without touching fuel pressure at idle and WOT. Their are chips like the bob bailey style that allow you tunability that you wouldn't believe.
Your combo sounds stout, it seems to me that you are using the alky to control knock but I believe that you lack fuel on the top end and have too much on the bottom end or at idle. If this is the case I really don't know if adjusting your fp is the only answer.
Do you have access to a scanning tool?
Old Nov 30, 2004 | 10:29 PM
  #140
mypontiac's Avatar
Car: 1991 Conv. TA
I used Data Master software to collect data to get the chip programmed.
I think I am ok with my current set up. Please note that I was only haveing problems with trying to use a smaller pulley which would throw off the air fuel ratio that the chip was programmed for.
I have a "REAL" A/F ratio gauge that I monitor my fuel ratio. Everything is as it should be. The fuel ratio was modified as needed during the programming of the chip.
I added the alky set up with the expectation that I would be changing to the higher boost pulley. I wanted the added insuranceto help prevent any predetonation running "on the edge". I do not have any knock issues with my current set up.
Sorry for any confusion. My current set up is great. It appears that I will need to make modifications to the fuel set up if I want to add the smaller pulley, due to the added air intake.
After talking to several friends, I will probably keep the turbo car stock. Don't need added work!
Old Dec 1, 2004 | 07:40 AM
  #141
No5.0's Avatar
Car: Buick
Engine: 231
Transmission: 200r4
Ya I would say 50lb injectors should be on the wish list along with a warlboro 340 pump and a dyno tune.
How much did the current chip cost you?
I am very interested in your setup because it is the way I would go if in your shoes. Do you have the D1sc blower?
Old Dec 2, 2004 | 10:56 PM
  #142
mypontiac's Avatar
Car: 1991 Conv. TA
I forget the cost of the chip (About 2 years now), but it was very reasonable. Contact list member Rooster433 at Rooster433@aol.com. He programmed my chip.
I have the D-1sc. The only way to go!
For my kit, Contact Dave at : http://www.tenperf.com/
Let me know if you have any more questions.
Old Feb 20, 2005 | 10:12 PM
  #143
ConfusedGarage's Avatar
Ok at this link some people are questioning the original setup of willie. they seem to think that running the system in parallel would be better than the way it is. please post replies for all to see on either board.
http://www.michiganmodded.com/forums...opic.php?t=650
Old Mar 18, 2005 | 07:00 PM
  #144
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
What are the dimensions of the intercooler cores? (Specify with or without tanks.)
Old Mar 19, 2005 | 12:51 AM
  #145
Synapsis's Avatar
Car: Sexy
Engine: Stock
Nevermind, found it. 11x9x3 or 11x9x4.5
Old Mar 19, 2005 | 08:07 AM
  #146
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Strange, those IC's look like the stock MX6/Probe ones! I only know that because I had one on my turbocharged Caravan
Old May 29, 2005 | 05:46 PM
  #147
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
anyone go through with this intercooler setup on a turbo car yet?
Old Nov 14, 2005 | 02:57 PM
  #148
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Now , you got me real curious You are talking like that older probes ...not the last ones they made right ?
Old Jan 24, 2006 | 01:23 PM
  #149
JBert's Avatar
Car: Looking
Any updates?
Old Feb 10, 2006 | 09:25 AM
  #150
Ponyhntr's Avatar
Originally posted by KS91Z28
Ok, here's the list of parts you'll need.
(QTY)
1 AIGJ1A-1 (LS1 F-body I/C (right side)
1 AIGJ1A-2 (LS1 F-body I/C (left side) - these will need to be modified by you
for a scoop, see Willie's pictures.
1 AIGC2I-1 LT1 intake tube Polished or Satin - you will need to modify, see
Willie's pictures.
1 AIGC2I-2 Extended offset tube (MAF)
1 AIGC2I-21 Extended offset tube (speed density)
1 AIGI3I-2 Tube with surge valve bung
1 AIFC2I-4 Tube
3 AIGJ1I-6 Tube
2 AIGB2I-8 Tube
2 AIGA3I-1 Y-Tube (you will need to modify, see Willie's pictures)
1 RSST.065B-2.50 Raw tube 2.5" x 12" long section
2 ATR40I-90-1 2.5" 90 degree rubber elbow
1 ATR40I-45 2.5" 45 degree rubber elbow
2 ATR48I-090 3" 90 degree rubber elbow
2 AHR40B-000 2.5" X 4" long hose section
1 AHR40B-000 2.5" X 8" long hose section
2 AHR48B-000 3" X 6" long hose section
1 AHR64B-000 4" X 6" long hose section
1 AHR40B-000 2.5" X36" long hose section
1 AHF24B 3 ft long surge hose section
22 CL040I-1SS #40 hose clamps
8 CL040I-1SS #52 hose clamps
2 CL040I-1SS #64 hose clamps
1 RSAS.187B-1 3 ft of aluminum strap
If you want to order this stuff from ATI, don't sit there and try to list all this stuff off to the poor guy on the other end of the phone. Just send this to them in an e-mail or print it off and fax it to them. Also, don't try to get an ATI tech to help you figure this out. The techs that were around when this was developed are no longer there. (Believe me, I've tried.) Just check out the pics and stuff in Willie's sticky at the top of the page.
