SLP or LPE
Old Jun 28, 2002 | 12:07 PM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
SLP or LPE
I was wondering who all is using a SLP or LPE cam with the Juice?? I know they both make different cams but which one is used more. I am adding a few new things to the motor and I am stuck deciding between the two.
I have a 350 with SLP runners, Accel base, Afr 190 heads (64cc) and a Nx kit,,,,just cant decide on a cam. Any body using the LPE211?
Old Jun 28, 2002 | 12:56 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
I have an slp cam. Probably smaller than you would want to use though!!
Old Jun 28, 2002 | 02:11 PM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
You may want to look into the LPE 74219 camshaft.
Lift : 0.525" / 0.525"
Dur: 219 / 219
LSA: 112*
That is with 1.5 rockers. With the 1.6 rockers it changes to more like....
Lift : 0.560" / 0.560"
Dur: 221 / 221
LSA: 112*
I am running that in my Corvette right now with 1.6 rockers and I love it. With the full superram setup it pulls all the way to about 5800-6000 effortlessly.
I haven't even had time to tune the car yet and it is now ripping off high 12s @ 108-109 consistently in 90 degree weather and humidity where before in that type of weather it would only pull a 14.2 instead of it's normal 13.8s.
Linson
Oct 24, 2025 02:00 PM
no green
Jan 9, 2016 09:22 PM
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
Dragonsys
Sep 25, 2015 03:51 PM
