How much could my 355 handle?
Old Jul 30, 2002 | 07:30 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I'm still trying to decide what direction to take my motor. It's a 10:1 355 with forged flat top pistons. It's a given that I need to buy heads to replace my ancient fuelies, so I've been giving some thought to getting 76cc heads to drop compression in order to add a blower. I'm just not sure my motor can take it. It's a 2-bolt 355 with stock rods, and a stock crank turned 10/10. Forged slugs from a Summit rebuild kit, & moly rings. What kind of power can that rotating assembly support? I'm not looking for 100k mile reliability because I'm sure I'll build a new motor long before this motor reaches the 50k mile mark (Probably won't get to 25k), but I want it reliable for a while.
Old Jul 30, 2002 | 01:55 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I have run 450 RWHP on that same set up for years with nitrous even.
Old Jul 30, 2002 | 09:38 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hey Jim,
I'm running stock (cut) crank and rods, forged TRW pistons, but I'm running a little less compression with the 72cc heads..
9:1, I run about 7lbs boost, and its working well. I'd think you could even get away with the 10:1 if you kept the fuel good, and the timing low.
-- Joe
Old Aug 1, 2002 | 05:01 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I ran the TRW baby domes like .125" or so maybe they were .250" it was about 10.7 : 1
codeysabatini
Nov 10, 2015 04:07 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Numbah-1
Oct 2, 2015 08:27 AM
ndndndnd
Sep 28, 2015 08:00 AM
anesthes
Sep 18, 2015 12:34 PM
