View Poll Results: hp gains with both at 150 shot
125
0%
150
0%
160
0%
170
0%
180
0%
190
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
new parts I can use some opinions
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
Hello again, just got my new SLP 1 3/4 w.o air, and the 05151 NOS kit, I already am running the flowmaster 3" stainless american thunder cat.back, every free mod there is (other then prom burning)studying that right now), AFPR, airfoil, no cats, no emisions !#$!, no A?C, no backseats, optima in spare tire hole, Mammoth frameties from spohn, relocators and tubular LCA, factory panhard rod still((?)), no wipers, no washer tank, reinforced inner chassis structure, valve covers never removed, MSD total ignition other then dis., 160therm. with ecm switch, timing at 12bt, 51psi FP, cold air intake my fab, utillizing the ASDC ram air hood (16.5 lbs.), Dunlop D40 M2's inrear
I can keep going, but.. all want to know is with the new headers and Nitrous, what are your advise on tuning, timing, RPM switch settings,
Oh< Post some miss haps with Nitrous to I need to be put under control before I destroy my beautiful bird
Well, the headers are going to lean the engine out a little, so if you're running stoch with the FP you have right now, then you'll need to bump it up. The 1-3/4 headers are a little big for a 5000 rpm engine. You need a new intake and cam before you can make good use of the headers. Learn all you can about the nitrous, but don't be suprised if you fry the cluthes and bands after the first time you use it.
Transmission: 4l80e
thank you... is that all you guy's have to say, how about something more specific, or some prom tips on my setup
LT1Formula
20
Nov 14, 2015 12:02 AM
Thornburg
Aug 25, 2015 01:46 AM
