N2O on '88 IROC, what level is safe?
Old Aug 25, 2002 | 06:30 PM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
Hi everyone. I'm replacing the 176k mile bottom end of my '87 corvette with the bottom end of an '88 IROC becuase of a spun bearing. This is sort of a "patch" until I complete a new 383 during the winter.
The 'donor' engine has 92k miles on it and runs smooth. What would you consider a 'safe' level of Nitrous to run on this bottom end? I am planning on going with a wet kit from NX adjustable from 35-150 that would only be used against opponents that require it and at the track probably every other run. I as of this time plan on jetting it for 100.
The car makes 322rwhp & 362 ft/lb right now N/A and should be around 335rwhp & 380 ft/lb once the ECM is tuned properly.
Thank you for your time and experience.
Old Aug 26, 2002 | 08:32 PM
Chronos_Titan's Avatar
100 SHould be a safe level. If you really want to be safe run 50 and be sure to pull the timing back the appropriate amount. About 2 degrees per 50 hp shot.
Ron U.S.M.C.
Sep 7, 2015 08:38 AM
Thornburg
Aug 25, 2015 01:46 AM
BurlyChev
Aug 22, 2015 01:52 PM
BlackBoulder
Aug 11, 2015 11:15 PM
mustangman65_79
Aug 11, 2015 03:17 PM
