For you guys using the bottle....
Old Sep 11, 2002 | 08:13 AM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
I would like to know what cam and what cam profile you all are using with Nitrous and how you like it. I am building a 383 miniram engine, afr 190 heads, and I can not decide on a cam. Every time I think I found what I want, I find one that might be better.
I have been looking at the zz409 cam from TPiS and a couple from comp.
I know I could get a custom grind, but I would like to here from you guys first...
G0d Bless the United States of America and Everybody who stands with Her.
Old Sep 11, 2002 | 08:45 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
The ZZ409 cam is a good choice for a motor such as that. The ZZ409-X (I think that is the cam #) is even better - 226/240 instead of 226/226, which will evacuate the combustion chambers better (and idle about the same) on the bottle.
Two things to definitely consider getting: AFR Rev Kit and a stud girdle - both will keep valve float & rocker arm deflection to a minimum with a high revving nitrous 383.
Old Sep 11, 2002 | 11:19 AM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
I think the cam you are referring to is the zz-9x. I talked to TPiS about that cam and they said it would make great power but it would be a little soft down low.
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
