Fuel system on 400ci and larger (GP406Z)
Old Sep 24, 2002 | 11:57 PM
89406Iroc's Avatar
What are people doing for fuel system upgrades? Lines, pumps, Miniram fuel rail mods? Thanks
Old Sep 25, 2002 | 09:37 AM
bbunting's Avatar
Car: 1990 IROC Z
Engine: blown 390 CI
Transmission: TKO II
Just did a fuel system upgrade.
Summit racing 15 gallon cell with sending unit, dual -10 outlets
Aeromotive pump 11104
Aeromotive filter 12302
Ran a Y from both -10's into a -12, then into the filter, into the pump, -10 to the rails. -8 return line to the tank.
Old Sep 25, 2002 | 08:20 PM
GP406Z's Avatar
Car: 91 Z28
Engine: 406
Transmission: t350
I drilled a hole in the top of the tank , used a -10 bulkhead fitting,and bent a piece of -10 alum. line to mimick the shape of the factory stuff.-10 into a BG filter with a metal screen (DO NOT USE A PAPER FILTER HERE)-10 into the Weldon,-8 out,into a K&N 10 micron paper filter up to the as-shipped TPIS rail (except for a -8 inlet fitting,no other mods to rails).From the driver side rail -6 to a Weldon reg.,from the reg. -6 into the factory feed line used for a return.Fuel for the N2O is picked up from the -4 port on the reg.
works fine both on and off the spray,pressure is rock steady at 50# WOT.
later,
Glen
Old Sep 25, 2002 | 09:11 PM
89406Iroc's Avatar
thanks for all the input. I want to stick with the factory tank cause I drive the car alot. I am currently running the stock system except the 255lph fuel pump and adjustable reg. I think I need to upgrade this winter.
Old Sep 25, 2002 | 10:50 PM
bbunting's Avatar
Car: 1990 IROC Z
You can always add a sump to the factory tank. Are your 30 lb injectors at 100% duty cycle? If they are, calculate how much fuel you need. You may just need 36/42 lb per hour injectors.
Say 550 HP X .45=247.50
247.50/8=30.93 lb. per hr injectors
What is your rail pressure? If it is OK, you might just skip the fuel upgrade. If you have more HP, upgrade.
Old Sep 25, 2002 | 11:29 PM
89406Iroc's Avatar
Picking up pressure signal at line before fuel rail. Fuel Pressure is ok but I went to the dyno and it is leaning out on the top end. The dyno guy said it could be a fuel volume problem, saying that I may need bigger lines etc.
Old Sep 25, 2002 | 11:36 PM
bbunting's Avatar
Car: 1990 IROC Z
My stock lines were good to over 500 HP at the wheels. If you watch the FP gauge as you accelerate, does the pressure drop with RPM? We cranked my FP to 50 lbs at idle, and the injectors to 100% duty cycle, and on the dyno, FP dropped to 25-26 lbs. under WOT. LEAN. (15:1 A/F ratio) That would be a good test-watch the FP under load-if it drops with RPM, delivery problem.
Old Sep 25, 2002 | 11:41 PM
89406Iroc's Avatar
Fuel pressure holds steady. That's why I couldn't understand a fuel volume problem. Shouldn't pressure and volume be related. I am looking at stepping up nitrous this winter so I am going to probably plan on upgrade.
BTW bbunting do you have any pics with the draglites? What size are you running?
Old Sep 25, 2002 | 11:43 PM
bbunting's Avatar
Car: 1990 IROC Z
Do you have a chip of DFI? Need to check injector pulse width. Need to increase relative to RPM. Who did your chip?
Old Sep 25, 2002 | 11:45 PM
89406Iroc's Avatar
It's an Ed wright chip. Couldn't tell you anything about it other than what I am watching on my scan tool (snap-on).
Old Sep 25, 2002 | 11:48 PM
bbunting's Avatar
Car: 1990 IROC Z
Ed is top notch-call him and tell him EXACTLY where is drops off-he can fix it. Send the dyno graphs with the A/F ratio. Guessing that he can add some more fuel easily. Are you in IC?
Old Sep 25, 2002 | 11:50 PM
89406Iroc's Avatar
Who do you talk to? I call but I can't get by the guy that answers the phone. I don't know if he is just an order taker or what.
Old Sep 25, 2002 | 11:56 PM
bbunting's Avatar
Car: 1990 IROC Z
If they **** you off, go to Cerra Racing in Rock Island-they can burn you a Superchip while it is on the dyno-only way to do it right the first time. Didn't you go there already? With Jeremiah's gang? The did LS1 edit on my Vette and gained 21 HP/23 TQE.
www.cerraracing.com
Old Sep 26, 2002 | 12:00 AM
89406Iroc's Avatar
Yeah I was down there with their camaro gang . I don't know when it happened but I went racing the weekend after and I had terrible knock retard (16 degrees). So I don't know if it dyno'd OK or if it dyno'd with the retard. I am working on it now and am going to try to get it back down to do another pull and have some time to toy with some stuff.
Old Sep 26, 2002 | 09:03 AM
Lehrjet's Avatar
Hey
Hey C-
Its Jere with the TT WS6 and ghost flames. I would email ed its the best way to get ahold of him. ewright@gorilla.net he did my PCM on my car and the A/F was flatline perfect. He checks his email every night so email him today and he will have an answer for you in the morning. Otherwise Brian has delt with about every problem you can have on his camaro so he has alot of experience to share with. I am not much help but bbetween Ed, Brian, and Cerra you are in good hands.
Jere
Old Sep 26, 2002 | 09:40 AM
89406Iroc's Avatar
Thanks Jere. I'll try to e-mail hime tonight. Are you going to B-bops?
Old Sep 26, 2002 | 10:38 AM
Lehrjet's Avatar
No, i am in dallas till tomorrow. I have been traveling a lot for work. I goto Seattle next week, but i want to make it to b-bops saturday. Brian said he was going take his IROC there thursday, its a white one with a huge @$$ S/C on it, so if you go, look him up.
Jere
Old Sep 26, 2002 | 10:39 AM
bbunting's Avatar
Car: 1990 IROC Z
Uh, actually it blew another head gasket...so I will be taking the F350
Old Sep 26, 2002 | 05:21 PM
89ProchargedROC's Avatar
explain this to me...i've been thinking about it and why do you need a metal filter on the sunction side when there isn't hardly any pressure?
Old Sep 26, 2002 | 06:31 PM
GP406Z's Avatar
Car: 91 Z28
Engine: 406
Transmission: t350
Weldon pumps are gravity fed,they can`t suck fuel very well.The paper filter is way too restrictive to let gas pass thru it with no pressure to push it. Bob from Weldon told me to use a numerically higher than 100 micron filter before it (metal mesh is around 240 mic.)and a 10 micron filter after it.It has plenty of stregnth push thru the paper. I had a paper filter before it and would lose fuel pressure after about an hour driving around as it would starve the pump.Since switching filters,no more pressure drop and it isn`t as noisy.One of these days I`ll get the voltage controller to slow down the pump while cruising since the engine doesn`t need that much volume under those conditions
Myself,Tory and Don B. have our pumps/filters set up as per Bob at Weldon.
Old Sep 27, 2002 | 01:08 AM
BlownBird's Avatar
Only thing I would like to add to what Glen said would be... ALL efi pumps are pushers, and cannot suck through the paper filters.
Take a look at how a stock setup is. Has the large porus "sock" in the tank (before the pump). And the fine filter after the pump. Carcraft just had a big writeup on this a couple of issues ago, and suggested the same thing for all EFI fuel system setup's.
Old Oct 5, 2002 | 02:35 AM
LETHALRACER's Avatar
I have a Miniram and I hated how the fuel lines came out next to the TPS. No room there. So a friend of mine and I came up with an idea that works great for us. We took off the stock lines back to the hard lines that come up into the engine bay. We then went and got two 120deg -8, one 45deg -8, one 90deg -8 and about six feet of steel braided -8 fuel line. Connect the two 120deg fittings to the stock hard line on the frame. Connect the 45deg to the passanger fuel rail (intake). Connect the 90deg to the driver side fuel rail (return). Run the braided line down the back past the distributor, between the steering rod and the power brake booster and connect the hoses to the fittings and viola you are done. I great re route that is out of the way and looks awsome. I can get some pictures if you want them.
Old Oct 8, 2002 | 08:08 PM
bbunting's Avatar
Car: 1990 IROC Z
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
