got my FMU how do i hook it up?
Old Sep 25, 2002 | 02:20 PM
superirocz's Avatar
I got a vortech FMU of a mustang what do i hook the two fuel lines to? and I take it the vacum line goes to the intake.
Old Sep 25, 2002 | 07:21 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The return line..
WHats the ratio on the mustang FMU? the f-body is 8:1
-- Joe
Old Sep 25, 2002 | 08:20 PM
True Power's Avatar
IIRC, a lot of the Mustang ones i've seen are 12:1. I don't know is this is universal
Old Sep 25, 2002 | 10:45 PM
superirocz's Avatar
I can change the ratio no biggy, but which line goes where? The one line from the FMU goes into the bottom centre of the FMU and the other fuel line goes into the side of the FMU. Also does it matter what line goes to the fuel rail return and the return line coming from the gas tank? the FMU splices into the return line and blocks it when it sees boost increasing fuel pressure.
Old Sep 26, 2002 | 01:41 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
the fuel rail "return line" goes to the side fitting and the bottom fitting goes to the line that returns fuel to the tank. remember to use proper fittins to complete this install because FMU can raise the pressure to 80-100 psi and dangerous leak will occur. the FMU should have AN type fittings and buy two of these aeroquip items.
Old Sep 26, 2002 | 02:07 AM
superirocz's Avatar
great thats exactly what i needed
Z28/ZR1
Oct 23, 2015 01:04 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
Derrick86
Oct 1, 2015 05:12 AM
Gordonr1973
Sep 29, 2015 11:59 AM
