Twin Turbo GTA inside...........
Old Sep 7, 2003 | 04:47 PM
  #51
NTChrist's Avatar
I thought you were selling your car, Guido?
BBC and turbo's X 2. Niiiiiiice.
Old Sep 8, 2003 | 10:07 AM
  #52
bigals87z28's Avatar
Car: Check The Sig
Originally posted by Guido
Im working on it my friends. LOL
I work a full time job @ 50 hours a week so this stuff is all in my spare time right now. LOL
spare us the BS speach ok and get it done!!
hehehe just kidding.
Old Sep 21, 2003 | 01:00 AM
  #53
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
1/4 mile 9.73 149mph
1/8 mile 6.42 118mph
Old Sep 21, 2003 | 03:53 PM
  #54
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i wonder how that thing would like some intercoolers...hehehe
Old Sep 22, 2003 | 12:00 AM
  #55
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
He had intecoolers on it before, see pict in the thread........
Old Sep 22, 2003 | 12:49 AM
  #56
mw66nova's Avatar
Engine: 7.0L
yeah, i saw it, why did he take them off?
Old Oct 19, 2004 | 02:28 PM
  #57
JayBoCC2's Avatar
Car: '88 trans am GTA
Engine: 5.7L 355 TPI L98
Axle/Gears: eaton posi 3.73 gears
because intercoolers decrease boost and dont effectivlely cool incoming air for the loss in boost to be worth it... and the way he had it it was so twisty turney that it looked lame in terms of power boost.
Old Oct 19, 2004 | 04:02 PM
  #58
JPrevost's Avatar
Car: 91 Red Sled
If you're noticing a bit decrease in boost across an intercooler then it was too small/restrictive. A properly sized intercooler would make more horsepower if it doesn't heat soak. I'm sure you know all this but I'm just letting other people know that might be reading this.
Of course having a twin turbo big block you'd need a rather LARGE intercooler to not have that pressure drop. Then there's the whole problem of having a small thirdgen front end hence no reason for intercoolers.
You guys should try some extra fuel injectors aimed toward the compressor out. Don't aim it with the air flow, aim against. Cornell found more power doing this and they've been working with turbo's on their FSAE cars for years.
Awesome car! Just needs some traction because a twin turbo big block should be faster than high 9's. There are lots of n/a big blocks in the 9's and plenty of turbo v6's in the 9's in G-bodies. Then again when you're in the 9's you're in the 9's . Any faster and you're probably breaking drivetrain parts.
Old Oct 20, 2004 | 01:09 PM
  #59
BLOWN85/TA's Avatar
Anybody got the video or links to this Polly thing?
Old Aug 18, 2006 | 04:10 AM
  #60
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Some news on this sleeper..............
With 1120hk turbo engine
0-100km/t: 2,38sek, 0-200km/t: 6,55sek, 0-300km/t: 14,88sek.
0-201m: 6,42sek-191km/t, 0-402m: 9,73-239km/t.
60 ft: 1,61sek.
Max speed driven: 358 km/t.
New dyno sheet with procharger
Attached Thumbnails Twin Turbo GTA inside...........-aac.jpg   Twin Turbo GTA inside...........-procharger_400.jpg
Old Sep 5, 2006 | 10:08 PM
  #61
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
Anyone have some functioning pictures of the whole car? I did a search and dug this thread up and the links arent working...
Old Sep 5, 2006 | 11:46 PM
  #62
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
here are some
Polly Motorsport
I have a few more at home I can post later.........
/N.
Old Sep 6, 2006 | 03:05 AM
  #63
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
countdown in 3...2...1... to some old man/idiot trying to tell you that boost is like nitrous and that its not run what you brung.
Old Nov 21, 2006 | 02:46 AM
  #64
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Finally.... Movies of this beast!!!!
Check out the tire explosion in the 1407hk No2 movie .
There are some old movies to with only 720hk...........
http://www.pollymotorsport.no/index....view_album.php
Old Nov 21, 2006 | 04:31 AM
  #65
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
According to wikipedia
1 Swedish hästkraft (hk) and Norwegian and Danish hestekraft (hk) also equals the German Pferdestärke (pk) = 0.73549875 kW
so 1407 kh divided by 0.73549875 = 1034.84674125 kW
According to google
1 kilowatt (kW) = 1.34102209 horsepower (hp)
1034.84674125 kW X 1.34102209 = 1387.7523397807642125 hp
or roughly 1400 hp so in this case the hk rating is very close to a unit for unit hp rating.
This puts his motor above the levels of hp found in F1 cars and in the neighborhood of twin engine off road race cars. His torque is well above any of those, making him the literal king of hp among anything required to make turns...on the ground
Old Nov 21, 2006 | 10:35 AM
  #66
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Performance:
0-100km/t (0-62mph): 2,23sek
0-200km/t (0-124,3): 5,55sek
0-300km/t (0- 186,4): 12,92sek
0-201m (1/8mile): 5,91sek-205km/t(127,4mph)
0-402m (1/4mile): 9,19-249km/t (154,7,ph)
60 ft: 1,45sek.
Max drive speed: 358 km/h(222,5mph)
Weight: 2000kg+
Old Nov 21, 2006 | 11:47 AM
  #67
PeterFeix's Avatar
Car: Trans AM GTA 1989
Engine: 383 HSR AFR195 JRC Cam280/286
Transmission: T56 Conversion
Axle/Gears: 3.27 9bolt
holy ****
i want that car
even faster than the weineck cobra in it's most powerful option
hope to see the t/a someday, would be worth a short trip to norway or sweden
Old Nov 21, 2006 | 01:27 PM
  #68
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
you do know that the fastest way between two points doesn't involve tire smoke, right?
Badass car!!!
Old Nov 21, 2006 | 02:03 PM
  #69
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Badass car!!!
Short of reducing the horsepower, or making it into a drag car, what would you propose he do?
I mean because reducing power to half still generates the tire destruction at wot.
Old Nov 23, 2006 | 11:42 PM
  #70
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
2.1/8" headers
3.5" collectors to a single 5" pipe over the rear axle
Old Nov 25, 2006 | 03:56 AM
  #71
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Rumours says that he will take tha car to US next year, some high speed autocross race in Nevada.......... watch out
Old Nov 25, 2006 | 04:14 AM
  #72
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
i think i'm in love with that car.. good god!!!
Old Nov 25, 2006 | 05:06 AM
  #73
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Silver State Classic in the unlimited class...........
Weight 2025kg!
Old Dec 5, 2006 | 05:27 PM
  #74
Steven89Iroc's Avatar
Oh my goodness!
Old Dec 5, 2006 | 09:09 PM
  #75
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
HO-LEE... CRAP...
0-60 in just over TWO SECONDS??!?!? That's just over half the time it takes to do 0-60 in the McLaren F1!! Gotta be some serious traction issues there...
Not sure about the ability to plant that power at less than triple-digit speeds, but I know one thing for sure -
It definitely makes the (roughly) 550 HP turbocharged 383 that I'm thinking about seem positively weak...
Old Dec 8, 2006 | 04:13 PM
  #76
327???'s Avatar
ummmmm....thats a good question. how about some slicks, one video was a 10sec street tire run. i don't know what to do when turns are involved though, another video was just turn, tire smoke, turn, tire smoke, turn tire smoke. ridiculous, just ridiculous.
Old Jul 12, 2007 | 12:58 PM
  #77
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Re: Twin Turbo GTA inside...........
News:
Track tested on a wet track 394,2 km/h (= 244.94mph)
4th gear to 235mph then shifted to 5th gear and after a while the transmission broke ......
http://www.bt.no/forbruker/bilogmotor/article382875.ece
Plans to race the Silver State Classic Challenge i Nevada in september
badass car
Old Jul 25, 2007 | 09:21 PM
  #78
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Two video links of new stuff
http://youtube.com/watch?v=Cm4DdYPP5Lw
http://youtube.com/watch?v=18W2nL34QHU
Old Jul 25, 2007 | 10:18 PM
  #79
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
^ Now that is just SICK!
Old Jul 25, 2007 | 10:58 PM
  #80
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
Old Sep 11, 2007 | 02:39 AM
  #81
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Car and driver is now i LA, 16/9 its time for Silver state challenge.
/N.
Old Sep 11, 2007 | 01:08 PM
  #82
Stephen's Avatar
Car: 87 GTA
/N.
Old Sep 12, 2007 | 12:17 AM
  #83
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
the 16/9 the car will be in Vegas
Silver state challenge "unlimited class" http://www.silverstateclassic.com/
Aiming at new speed record. Would be nice if a 3'gen beats all new supersportcars.... Todays record is 207.7801 Mph average under 90 miles
/N.
Old Sep 12, 2007 | 07:59 AM
  #84
Stephen's Avatar
Car: 87 GTA
What is 16/9?
Big Red set the record of 197.99 in 1989, but lost the record in 2000, to of all things a Chrysler LeBaron!!! But Big Red hasn't been back since.
http://www.silverstateclassic.com/results-07-norc.htm
This years average top speed was only 169.9584 mph, in the 170 class. Only 1 person entered the Unlimited class, and he DNF.
Old Oct 1, 2007 | 08:55 AM
  #85
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Results:
Shoot out 1 mile
3'e place 206mph
Unlimited class
2' place 181,64 mph average speed, top speed 222,5mph (highest sped of all cars)
http://www.silverstateclassic.com/results-07-sscc.html
/N.
Old Oct 1, 2007 | 08:26 PM
  #86
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
Originally Posted by TPl383
LOLOL!!! that is just sick!
Old Oct 11, 2007 | 05:07 PM
  #87
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Pedal it, don't go full throttle. R-compound tires.
Old Oct 11, 2007 | 06:25 PM
  #88
Stephen's Avatar
Car: 87 GTA
I guess we'll never know what '16/9' means...He's not telling...
Old Oct 13, 2007 | 11:47 PM
  #89
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
16/9 is the same as 2007-09-16 or 9/16-2007, its the date.
date/month is normaly the way we write date here in sweden...
/N.
Old Feb 25, 2008 | 02:01 PM
  #90
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Bring back on "old good post"....
A movie from norweigen TV, dont mind the language but its fun to see ....
http://www.pollymotorsport.no/index.php?mapping=73
Old Feb 25, 2008 | 06:50 PM
  #91
Dr G's Avatar
I love this car! It was even mentioned with a small photo in EVO magazine in the UK when they were featuring his friends GM Saloon / Vauxhall Omega with a 1000bhp supercharged Lexus engine.
Old Dec 16, 2008 | 01:08 AM
  #92
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
0-62.14 mph 2.23s.
0-124.28mph 5.55s
0-186.42mph 12.22s
1/8 mile 5.91s/127.39mph
Wieght: 4488lbs
Top speed 253mph ( http://www.pollymotorsport.no/index....t&nyhets_id=32 )
http://www.pollymotorsport.no/index.php?mapping=2
Old Dec 16, 2008 | 04:10 AM
  #93
VAN454's Avatar
Car: 88 GTA
Engine: Ls1
Axle/Gears: 9 bolt 3.27
I love this car, I just wish the site was in english.
Old Oct 22, 2009 | 06:54 PM
  #94
walrus108's Avatar
Car: 1989 GTA White Hardtop
ZOMBIE POST!!! Oct is the month to bring back the dead, right?
I just found out about this car so I'm reading up on it. Anybody know what happened to it and where it is now?
I had a few questions about it too. I don't like too many types of wheel on a 3rd gen usually, but I just LOVE the looks of these! Does anybody know what these wheels are?
And I've seen similar hoods but this one looks a little different. Anyone know what exactly it is? Who makes it and where I can get one?
Also, is that nose piece custom made or can that be purchased? I think it looks awesome and it would be a functional improvement also.
Old Oct 22, 2009 | 10:08 PM
  #95
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Holy old thread batman!
The car is still around, I remember reading something recently about it being the fastest street legal car in europe.
http://blog.cardomain.com/2008/12/23...icks-euro-***/
Old Oct 22, 2009 | 11:57 PM
  #96
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Still owned by the builder I think.
Wheels are BBS 9x18" , 12x20"
Hood is a ram air I hood
Front is a stock GTA front with a cutout in the middle, the x-tra lip was put on for the silver state cup.
Old Oct 26, 2009 | 06:04 AM
  #97
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
got an email today from Pål (owner/builder)
car is to be seen in a tv show, germanys version of BBC top gear.
http://www.amcar.no/page.asp?ParentI...D=8986&Order=2
an old videoclip
http://www.youtube.com/watch?v=EwMNqqO1KIE
Old Oct 26, 2009 | 11:11 AM
  #98
walrus108's Avatar
an old videoclip
Looks very interesting. Something about trying to prove the car is faster than an arrow? is my translation right? lol
Hope the show clip makes it online. Post back if you see it online someday.
Old Oct 27, 2009 | 12:18 AM
  #99
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
wow, this car is insane and this thread is old. I'm surprised the engine didn't blow up...
Old Oct 27, 2009 | 07:01 PM
  #100
walrus108's Avatar
Lol! I thought the same thing. But the block he used, I think, is the same one top fuel dragsters use to make like 6500+ HP. So he's actually babying the block. And I don't think you can really buy 2nd rate parts to fit that block. I would like to know what crank, rods, etc, that he used for this. And how much he's got into it money wise.
Why hasn't 'Hot Rod' or 'Car Craft' done a write up on this car? This seems to be the definition of what our hobby is all about, to the nth degree!
I think I will try to get one of the editors or writers of those mags on the phone tomorrow and encourage them to cover this car. I would not be surprised if they've never even heard of it!
