vortech superchargers
Old Oct 15, 2002 | 08:08 PM
no_car_yet's Avatar
I figure its a great way to waken up my 305. Does anyone here have one? Does anything else need to be bought/upgraded to help the supercharger? its says MSD BTM ignition, so is that something i need to buy o what?
Is the kit actually comlete and you need nothing else?
and last quesion, is 8-9 psi safe to run on stock internals. BTW; by the time i get this(end of next summer) i will have my*future* mods in my sig done, if that helps.
Old Oct 15, 2002 | 10:17 PM
sprchgdirocz's Avatar
i have a paxton not a vortech, 8-9 is max u should run on a stock bottum end internals... i have an msd coil and ign, and i recomend it or a btm.. also... the kits are compleate but id recomend a few solid days and ur going to find ull need alot of little things from auto shops, just small things like bolts and ****
Old Oct 16, 2002 | 05:22 PM
no_car_yet's Avatar
so when i order one should i get it set at 6,7 or 8 psi. I want it to be as fast as possible but i don't want to loose my motor, for at lease 3 years...then i can afford a 350 build up and i'll slap the super back on there.
the car will get a good bit of regualr use and probably get out to the drag strip a couple of times a year. what psi setinmg would be best. my top end of the motor should be strong enough to with stand the psi, but what can i run SAFLY on the bottom end?
Old Oct 16, 2002 | 05:44 PM
YenkoZ28's Avatar
Car: 1991 Z28
Engine: 305 TPI under 14 psi
Transmission: aftermarket T56
Axle/Gears: Moser 12 bolt 3.08 gears
You may want to go with 6psi nonintercooled just to stay on the safe side of things.
anesthes
Sep 30, 2015 07:48 AM
c350b
Aftermarket Product Review
Sep 26, 2001 07:28 PM
Chris Etemadi
Apr 25, 2001 04:46 PM
Dan87IROC-Z
Apr 4, 2001 08:13 PM
LilJay
Oct 25, 2000 07:59 AM
