LT1 with ported stock heads and high boost?
Old Nov 11, 2002 | 09:09 AM
LT1guy's Avatar
Car: 1987 Trans Am
I know that AFRs have thicker decks and are better suited for high boost applications (20 psi or more), but am I going to have head gasket (or worse) problems with the stock castings? I plan to use ARP studs regardless. I already have a set of Lingenfelter worked LT1 heads, and will go LT1 with my project if I can use them. If not, I'll probably just build a regular SBC. Any opinions?
Old Nov 11, 2002 | 11:23 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
LT1 heads end up with a very small chamber after you start with a 58 cc head, mill it flat etc, requiring deeeep dish pistons if you want low enough compression to run high boost, www.flatlanderracing.com has the LT4 AFR for about 1600 which you can get with a 70cc chamber.
Old Nov 11, 2002 | 11:36 AM
LT1guy's Avatar
Car: 1987 Trans Am
Thanks Z28 Racer, the 58cc chamber was also a concern that I failed to mention. Looks like my girlfriend Shannon is getting a set of Lingenfelter heads! I'll look into the AFRs, thats a much better price than I've been seeing.
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
camaro71633
Sep 1, 2015 10:24 AM
BBSDesigns
Aug 11, 2015 07:39 PM
Thirim
Aug 9, 2015 06:19 PM
