350 T.P.I Procharher w/D-1 15-20P.S.I Boost
Old Nov 21, 2002 | 11:28 PM
CustomCarShop's Avatar
I have a 1988 IROC-Z with a 305 T.B.I curretny. I also have a 350 T.P.I enigne with harness & ecm & everything, I am doing the swap when I am done building the motor. The guy who is building it for me is aiming for a minimum of 450HP. I am also looking to buy the Procharger kit with D1 for the 350 T.P.I Motor that runs 15-20 P.S.I boost & has a 3-core intercooler. It says it gives a minimum of 85% Increase in horsepower. I am wondering iof anyone has this set-up in there car or knows anything about this set up & what there thaughts are?
Thanks.....
Old Nov 22, 2002 | 02:25 AM
89ProchargedROC's Avatar
bye bye stock pistons.....
that is too much for the compression of that motor unless you retard the timing via a boost retard or you turn it down via a chip
Old Nov 22, 2002 | 08:59 AM
BigMike92Z's Avatar
Car: 2006 Pontiac GTO
Transmission: rowing through 6 gears
ping... ping..... ping..... ping ping ping ping ping ping booom....
bye bye new motor...
unless you build the motor to handle that much boost then you'll go nowhere fast.
Old Nov 23, 2002 | 06:21 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
it probably wont blow your motor's pistons, because of the known safety feature for protecting them. Its called blown head gaskets. But dont bet on it.
Old Nov 23, 2002 | 10:34 AM
88IROCZ350's Avatar
well its not necessarly bye bye.
what is the guy putting in your new motor for internals? forged?
what will the compression be. These are the major factors, find that out first
Old Nov 24, 2002 | 12:06 AM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
I actually hope to build an engine similar to what your speaking of. Friend of mine is running an engine he built to run 18lbs of boost. It's 8.5:1 compression, all forged components, oringed block, at this moment he's only running 12lbs boost, and recently ran 9.55 at 145 in a 3500 lb car on pumped gas. If your engine is built to take the boost then you won't have any problems. But don't bolt on 15-20lbs of boost on a stock bottom end and expect it to take it.
Old Nov 24, 2002 | 10:04 AM
I am not sure as of yet what he will be doing to the motr internally. But he is setting it up for what the supercharger will need / motor to take the abuse.
He also mentioned that I should throw a nitrous kit aswell. Now when I first talked to him, he said it would be no problem, and he would build the motor to take more than what this supercharger & nitrous will give it.
Not only that, This kit is intended for the 5.7T.P.I 88-92 Camaro Only. I dont think the company would make this kit if the 350 wouldnt be able to take it, and yes I do know that the engine does have to be built better then stock, but it should be able to take it no problem if the engine is built correctly.
Old Nov 24, 2002 | 03:33 PM
gflo383's Avatar
Car: IROC Z
Engine: 355 MINIram w/boost
if you running 9.5:1 comp. ATI recomends no more than 12psi of INTERCOOLED boost...
Old Nov 25, 2002 | 08:33 PM
Okay, what if I run 9.0:1 compression or 8.5:1 or even less? It should be able to hold more boost, right?
Old Nov 26, 2002 | 04:31 PM
88IROCZ350's Avatar
yes you will be able to run more boost safely but when you get down below 9.1-1 many people say that your throttle response starts to suffer. I have no experience because i have not used anything under a 9.1-1 ratio. I would say run 8.7-9.1-1 and used forged internals. my best advice is this, do it right the first time and not have to worry about it later. save yourself the hassle of blowing a brand new motor and built it right and it should last you long enough.
Old Nov 26, 2002 | 10:27 PM
Awesome, ill keep you posted when i know what he wants to with the engine.
buffaloman
Firebirds Wanted
Sep 7, 2015 09:47 AM
buffaloman
Camaros Wanted
Sep 7, 2015 09:46 AM
tgp1990
Sep 4, 2015 06:24 AM
85Special
Sep 3, 2015 04:21 PM
Formula_88AE
Sep 3, 2015 01:47 PM
