NOS nozzle, Dry, in vortech tube
Old Nov 22, 2002 | 12:22 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hey guys,
If you spray the nos _AFTER_ the supercharger, it should only freeze/compress the hot air from the supercharger, not change how much air enters the motor right?
I'm curious if I'd need more fuel.
-- Joe
Old Nov 22, 2002 | 01:32 PM
Skweezn87's Avatar
Car: 78 Vette Pace Car (730 ECM MOD)
Engine: 427 SBC
Yes.. you will need fuel... as when its combusted..it will split..and make more oxygen..
and it will also have a cooling "effect" as well...
Rick
Old Nov 22, 2002 | 01:34 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Ugg. thats not really an option.. Allready have an FMU.. Guess it would have to be a wet system huh?
-- Joe
Old Nov 22, 2002 | 02:43 PM
jimmbo's Avatar
remeber n20 is an oxidizer
so the oxygen content will definately be greater and need some matter of fuel compensation.
jimbo
Old Nov 23, 2002 | 06:19 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
the only failed FMU diaphram I have ever seen came from a "dry" kit blown car, and it hydraulic'ed a piston and bent a rod (not discovered till the end of season tear down). Against my estimations, wet flow kits seem to work well enough on FMU'd cars even though the FP is much too high for the kit during its cycle. I have been amazed to see how well they work on blown apps, that I have considered running my #5151 kit on the blown 91 when it is done. go figure...
Old Jan 2, 2003 | 07:11 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Tom,
Would you run a plate over a fogger in the discharge tube?
-- Joe
Old Jan 2, 2003 | 03:17 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I would probably run a single fogger, but I already have a plate so that may be the deal for me.
gixxer92
May 18, 2017 11:20 AM
no green
Jan 9, 2016 09:22 PM
FormulasOnly
Oct 2, 2015 05:52 PM
zman1969
Oct 1, 2015 11:09 AM
anesthes
Sep 30, 2015 07:48 AM
